Question about ACCO Brands Office Equipment & Supplies
REXEL rdx1750 SHREDDER- RED LIGHT ON ALL THE TIME - NO PAPER STUCK AND BUT CAN'T GET IT TO MOVE BACK - LIGHT SHOWING PAPER FULL BUT IT'S BEEN EMPTIED BUT STILL NOTHING. ANY IDEAS?
2 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel ยป Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
My shredder is showing the bin is full when it is empty - how to I fix it?
Depending on the shredder model, there is a sensor of some kind telling it that it is full. The two possible solutions are to unplug it and plug it back in, and to try to find the sensor and do what needs to be done to make it not active.
Dec 03, 2014 | OfficeMax Om04229 15-sheet Diamond-cut...
Rexel rsx1227
The sensor may be blocked with shredded paper.
Oct 24, 2013 | Staples SPL638X (CrossCut) Shredder
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Apr 15, 2009 | Royal 15MX Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Mar 01, 2008 | Office Equipment & Supplies
Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Jun 03, 2007 | Shredder 1052 (Cross-Cut)
106 people viewed this question
Top ACCO Brands Office Equipment & Supplies Experts
Adorjani Laszlo
Tom Chichester
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
