Question about GE Spacemaker JVM1750 Microwave Oven
Need to remove ge JVM1750 - GE Spacemaker JVM1750 Microwave Oven
  • GE Master
  • 9,047 Answers
You can download GE owner's manuals and installation instructions here.
Posted on Oct 06, 2009
GE MICROWAVE TRAY (PLATE) WILL NOT TURN
1) small motor defective repair or replace
2)plastic drive coupling+ring and rollers you must shure is working properly, fix it.
God bless you
Jul 17, 2012 | GE Spacemaker JVM1750 Microwave Oven
I have a new JVM1750 just installed yesterday. There was some arcing, in what looked like underneath, a white circular disc in the ceiling of the internal cavity. Have checked for foil - none inside the...
That is your stirrer cover.
Any arcing there is usually due to grease or food particles, so on a new oven that would be as mystery.
But any time you get arcing under it, it has to be removed and cleaned.
Oct 12, 2011 | GE Spacemaker JVM1750 Microwave Oven
NO POWER / HOW TO LOCATE FUSE IN MICROVAVE
fuse is usually located behind touch panel on or near computer board
Dec 25, 2010 | GE Spacemaker JVM1750 Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot remove the grill on my ge JVM1750 according to manual. Found and took out both screws BUT grill would not come out. What else is there to do in order for the grill to be able to come off?
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Dec 04, 2010 | GE JVM1750SMSS Microwave Oven
I have a GE space saver Model JVM3670 - it is not heating up
Generally if everything else looks like it is working fine, then the magnetron has quit and needs to be replaced. The magnetron is the part that heats the food. Unfortunately, it is common for this part to fail on GE microwaves and it isn't worth replacing as the cost of the part is almost the same as buying a new microwave.
Let me know how this works out for you.
Benjamin
Apr 30, 2010 | GE Spacemaker JVM1750 Microwave Oven
The microwave oven does not have power to the panel.
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Jul 02, 2009 | GE Spacemaker JVM1750 Microwave Oven
I recently bought a GE microwave JVM1750 and we have somehow lost the installation instructions. can you help me?
Aug 09, 2008 | GE Microwave Ovens
GE Spacemaker JVM1750 Microwave Oven Logo
268 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
