Question about Acer Aspire 9300-5349 Notebook
My monitor on my notebook is a white screen.
My monitor on my notebook is blank. What can I do to fix it? F8 function doesn't reboot it at all. Haven't had it a year yet.
    Genius:
  • Acer Master
  • 1,252 Answers
Check the display on external monitor by attaching it to a vga port of the laptop, if the display is there then its the fault of the screen , if its not then its the problem on motherboard better take it to service centre or to some technician
Posted on Oct 05, 2009
Screen driver problem notebook
Might be a hardware problem as well. To make sure it is not, boot to "VGA mode" (see below), keeping the external monitor disconnected, and see if the problem is still there on the laptop screen. If the problem disappears, then it's more than likely that a driver update will solve your issue. If this is the case, uninstall the driver for your graphic card, download the latest one from the manufacturer's website and install it. If not, then you need a more in-depth look, maybe you have a faulty LCD display.
To boot to VGA mode, press "F8" repeatedly while rebooting your computer and select the appropriate choice from the black and white bootloader screen that will appear.
Sep 10, 2014 | Dell Computers & Internet
Computer screen is white and blank..the last thing i did was run a disk defrag and now its completely white...i dont know how to reset the monitor and i hook it up to my laptop to a double monitor options...
Not sure what you mean by resetting the monitor but pulling the power should get it back so you can see the Onscreen menu. If you can get inot the menu there is usually a reset or factory reset option.
As for dual screen w/laptop. The hardest part is telling the laptop to use the extra monitor. On my laptop the Function Key and F8 cycle the external monitor. You also need to tell windows if the new monitor sits to the left or the right of the laptop so the mouse works correctly.
Mar 08, 2014 | eMachines E17T4W 17" Monitor
My screen will just be black after when it should go to the blue login screen. how do i fix it?
In the BIOS setup under Video choose the built-in adapter and no Dock video. Save and Exit BIOS setup. The system reboots. If it does again doesn't give you the blue login screen, press and hold the power button to shut it down. Restart it again and immediately after the Dell screen press and hold Function & hit the function key with the display on it. I think it believes you want your primary video to go to an external monitor. This should correct it if that is the cause of your boot-up blankness.
Dec 15, 2011 | Dell Latitude D600 Notebook
I have blue,white and green lines across my monitor.How can I fix it.
If you can find a monitor to connect to and know how to tell the PC to send a signal to it (ie, on a dell it is Function F8) you can determine if it is your Video card or your screen that has failed.
I do not know any function the tells a computer to give a white and greenlines on the screen screen.
Sorry!
Aug 06, 2011 | HP Pavilion zd8000 Notebook
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
Screen not working but other monitor work
Your "F"keys are multi function. Look for the one with a picture of a monitor. Press the FN key adt the appropriate F key at the same time. You are probably in remote monitor mode. The F key is usually F5 or F8.
Dec 15, 2009 | Acer Aspire 9420-6426 Notebook
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Turning on but remains blank screen
it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
Aug 20, 2009 | HP Pavilion tx1000z Notebook
Aspire 2920 won`t start up
As it's rebooting try tapping the F8 key to get to safe mode. Choose Safe Mode with cmd prompt first. Once your pc starts enter the text chkdsk /f in the black DOS box and reboot. The laptop should go though a check disk and fix problems. May not completely repair your laptop, but it's a start.
Mar 17, 2009 | Aspire Acer 7520-5071 Notebook
Screen suddenly blank on FujitsuSiemens AmiloProFB21
I am thinking that the Video Resolution went off, so you have to try entering Safe Mode by pressing F8 until you get a menu in black and white...
Then, select Safe Mode. That would reset your video resolution.
Then, reboot the system and let it boot normal. See if it is fixed.
Jul 20, 2008 | Fujitsu AMILO Pro V1000 Notebook
Acer Aspire 9300-5349 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
