Question about Hoover Washing Machines
Drain pump not working i have a new drain pump voltage to it is around 70v ac
Recently the water would not drain from my indesit WIDL 126S machine, I have done all the obvious checks, everything looks as it should be. after doing a little research somethings pointed to the pump maybe being past its life span. so i have replaced it, and still its not working.
when machine is in cycle alams 2 and 4 flash, when drainage is required then machine stops what it is doing.
when machine is selected for drainage only, door locks and few minutes later door unlocks with water still in machine.
the machine is about 5 yrs old, is it time for a new one? or is there something else that may be worth checking?
Posted on Sep 14, 2010
I have a carrier model 58sta110 that does not come on at all when I try to turn on the Ac. The led is OFF continuously
70 Volts is too low. IT should be the same as the house voltage. Check the outlets and breakers.
Sep 12, 2014 | Heating & Cooling
Water will not drain out?
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 21, 2010 | Dishwashers
Dishwasher does not drain dirty water
Jan 20, 2010 | Maytag 24 in. MDB8750AWS Jetclean II...
Frigidaire Dishwasher
Jan 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't drain water at end of cycle.
Jan 19, 2010 | Dishwashers
Water will not drain. Do not know if its a drain
Jan 19, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a model DUB40CWBB3 dishwasher, it will not drain, can I just use a plunger or does this need a pro?
Dishwasher will not drain water
Jan 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Standing water in the bottom of the dishwasher
Jan 18, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Model kudsoiflwh6 dishwasher will not drain. pump motor is working
The pump motor has an impeler inside. Is the motor working AND the impeler spinning / turning?
Is there any obstruction in the outlet pipe?
Jan 18, 2010 | Dishwashers
Washing Machines Logo
101 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
