Question about Nikon COOLPIX S6 Digital Camera
How to Charge my Nicon cool pix from Laptop? I used to use USB Cable to charge it.,but it is not working .Please help !
5 Suggested Answers
  • 102366 Answers
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Posted on Jan 05, 2010
  • 194 Answers
SOURCE: My Nikon S4000 (black) won't charge. I've tried
Follow this order:
when plugging in the camera and then plugging into the compuer does the computer recognise it? If not this is either a bad cable, or not an active USB port, or something has gone wrong interanlly with the camera. Internal can be anything from bad voltage chip to bad battery. But some people have put the battery in backwards or with the positive terminal the wrong way. Double check that this has not happened, as anyone could have done it, unless you live alone. Try another computer and see if it recognises that camera if so the cable is good and you can continue to trouble shoot in other areas.
Posted on Mar 11, 2011
  • 147 Answers
SOURCE: My Nikon S4000 (red) won't charge. I've tried
The battery itself won't charge in-camera like a cell phone-- you'd need to remove the battery and plug it into the supplied charger (EH-68P). You may have an ac adapter for the camera that basically would just be used to power the camera without a battery or for long periods of time without relying on the battery. It wouldn't be used to charge the camera.
Posted on Mar 12, 2011
  • 6771 Answers
SOURCE: cool pix s4100 won't charge
If this is a brand new camera, take it back to the place of purchase and have it checked, if battery is used then it will need to be replaced.
Posted on Mar 14, 2012
How can i charge my nokia 1110i to USB cable. I have my USB cable and connect to my laptop but it doesn't work. Is there any driver needed to install it?
No you could not do this because there is no cable other than Flashing Easy Cable.Which will only be used by mobile technicians.Charge with travel charger is the only way.USB doesn't supports.Thanks
Nov 22, 2012 | Nokia 1110i Cellular Phone
My iphone is not detected in my laptop i use windows i am able to charge it through the AC adapted but iphone is not detected in my laptop please help
I am not sure that what cause that problem, but we could check where problem comes and fix it. Please ensure that you are using the correct USB cable to connect to laptop. There is an USB cable just use for charging, don't use that cable to connect to laptop.
Also if you use correct USB cable, could you change to another USB port, to check your USB port on laptop.
Do you have Itunes on your laptops? Iphone works with Itunes.
Hope this will help.
Feb 07, 2011 | Apple iPhone Smartphone
It's the purple digital camera-Hannah Montana, I do not know how to charge it, so that they can continue to play with it. I could download the photo, but what about charging the battery?
Hi, you charge this unit via a USB cable, you should have a USB cable that you connect to the unit and to any USB port, this then will charge your batteries up.
Either that or if it uses Normal batteries, one can simply use NON-rechargeable... and replace them when flat.
If it uses a Pack, then obtain a mains charger for that pack, and usually another battery,and use one and charge one.
Or one can obtain a suitable main battery charger, and use that, with the existing batteries, to charge.
Ebay would be your best bet for obtaining these things.
Aug 19, 2010 | Disney Pix Micro Digital Camera
I posses a nicon cool pix camera . I want to lern vedio making from still pictures as well as from video pictures.
Well then you don't want to use Flash, your probably wanting to use a program like IMovie (mac) or WIndows Movie Maker (windows)
Jun 16, 2010 | Macromedia Flash Professional 8.0 Full...
I bought a new htc touch diamond phone and within eight months the charger has stopped working. m not able to charge my cell through that charger.please give me d solution as i m not able to use d phone...
First of all your charger is under warranty, so you should get it replaced. Also you may use the USB data cable to charge this phone from your PC. Connect your phone to the computer/laptop using USB cable and it should charge as normal.
May 05, 2010 | HTC Touch Diamond Smartphone
Upload pix from motorola v3
IN MOTOROLA PHONES, THE USB CHARGING OPTION SO WHEN YOU PLUGIN TO PC IT WILL CHAGRE AND ALSO CONNECT THROUGH YOUR MOTOROLA PHONE DRIVERS IF YOU HAVE TO INSTALL. SO TRY TO CONNECT YOUR PHONE THROUGH USB WITH DRIVER AND TRY TO CONNECT, IT WILL BE AND THEN SHARE YOUR PICS WITH IT.
Oct 03, 2009 | Motorola Mobility RAZR V3
Is it ok to charge my controller on laptop/pc
There isn;t a reason why you shouldn't charge using a laptop/pc, did a bit of resaearch and many people claim to be charging thier pads via a pc's usb,
I tried it on mine and it didn't work, it recognised the PS3 pad and installed it as a game controller, which was pretty cool but it wouldn't charge, haven't tried it on my mac yet . If it doesn't work first time try a diff. usb port on your laptop pc, as sometimes its certain usb ports on your system that carry enough juice to power a device
d:)
Jul 31, 2009 | Sony DUALSHOCK® 2 Analog Controller for...
Can i charge my garmin 255w thru my laptop
Yes you can,Connect your nuvi to a computer using a USB cable.The computer must be on for the nuvi to charge.A camera USB cable can be used to do this,or any USB cable that fits both the nuvi and USB port on the computer.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Hanna Montant click pix
The Pix Click camera doesn't charge with the USB cable. It takes two AA batteries and you have to take off the faceplate to put them in. You can get a copy of the manual here;
http://digiblue.com/customer-service/downloads/index.html
Jan 24, 2008 | Disney Pix Click Digital Camera
Nikon COOLPIX S6 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
