Question about Texas Instruments TI-84 Plus Calculator
I have replaced the batteries but it won't start
I have replaced the batteries but it just won't start
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Posted on Mar 15, 2010
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
My 2001 Acura CL Type S won't start. It has been
You said that you replaced the battery so in either case of new or another battery have a load test done as what you describe indicates a failing cell in the battery or loose t/dirty terminals.
Sep 22, 2013 | Cars & Trucks
05 Kia sorento won't start replaced battery two
Do you have fuel pressure and spark to the plugs ?
Jun 30, 2013 | Cars & Trucks
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
OEM parts for Yamaha
YAMAHA XVS950A Owner Manual
May 31, 2013 | 2011 Yamaha V Star 950
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
My packard bell zg 5 won't start after the battery has drained. When I plugged the charger in, the battery indicator only keeps on blinking and won't start.
Try removing the battery and then connecting the power adapter and see if the laptop will start normally with no battery installed - if it does, then you should get a replacement battery.
Jan 05, 2012 | Computers & Internet
Hello I have a problem with my Pontiac 2002 Trans Am - Collector Edition. It does not want any more to start, there is the indicator SECURTITY which east lights, and since average making it...
Check the battery voltage with a multimeter. If the battery can't deliver a full 12 volts, the starter solenoid won't even activate. It may be that a cell went dead, causing a direct short inside the battery. Replace the battery if your battery is older than 3 years, or take it to an auto parts store to have it tested. The security light on is an issue many people have when the battery is low and the car won't start.
It is also possible that the security chip on the ignition key is worn. If it isn't making contact properly, the computer won't 'read' the resistor, and won't start. You will need to replace the key to see if this fixes the problem.
Aug 17, 2011 | 2002 Pontiac Firebird
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
95 jeep wrangler 4.0,won,t start,dash lites won,t go on.replaced starter relay.still won,t turn over.
Try checking the battery and battery leads. Sounds as though you have a bad battery. Also check your fuses under the hood and dash.
Jun 03, 2011 | 1995 Jeep Wrangler
Texas Instruments TI-84 Plus Calculator Logo
67 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
