Question about Mitsubishi WS-65809 65" Rear Projection Television
Rear projection - only blue lamp works, after set was moved
Set was working fine, sold it to a buddy, helped move it. We remove the top piece, down 1 flight of stairs. When we installed in at his house, only the blue lamp stays on. I say 'stays' because the red and green flicker at the beginning, but then shut off, leaving only the blue one.
Thanks
    President:
  • 4,402 Answers
Since you moved it i would look for a loose connection or loose board and loose plugs
Posted on Jan 10, 2008
Dlp lamp light blinks but tv will not come on
if the wheel is broken or missing pieces you get a grinding sound, and set will shut down as set sees it is not moving at correct speed.
with lamp removed look at the wheel.
Nov 27, 2012 | Samsung HL-S5087W DLP TV
Who do I determine what causes my tv picture to turn off
if your tv is one of the latest 2006-2012 it should have a prosesor and a heat sink on top of the prosesor, if the heat sink is not proparly positioned or has moved out of position due to unknown circumstances then all you need to do is reposition the heat sink you tv should work just fine.
Sep 03, 2012 | Panasonic SELECT PT50LC13 Rear Projection...
Can i buy a replacement screen for the front?
try contacting the manufacturer. without more information about the make and model that's the best I can offer.
Feb 02, 2018 | Panasonic PT-53WX42 53" Rear Projection...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
Red Green Blue Across The Screen
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Dec 06, 2007 | Sony KP-46WT520 46" Rear Projection...
Red Lamp Light
The problem lies in the heat sensor that sits just inside the lamp housing area inside your set. Apparently the technician fix is to clip the faulty connector Mitsubishi used when assembling the set and replace it with a soldered connection instead. My fix is simpler and does not require solder. My TV is a 57831 model so it may differ from others but not much if so. Here is what I did.
1.) Remove the two screws holding the lamp door to the set in the back lower right corner of your set.
2.) Follow the set instruction for removing the lamp assembly. it should be unplugged for an hour prior to doing this.
3.) Once assembly is removed, grab your flashlight (if necessary) and look inside the housing. You should see a white rectangular shaped piece attached to the outer frame edge of the opening. Looking straight on, it is located in the upper left corner of the square opening and is held in place by one small phillips head screw. This screw is inserted and installed from the opposite direction and will require the short screwdriver to remove. Carefully remove it and don't drop inside the set!
4.) To make room to move around and do what you'll need to do, you will also need to partially remove the back cover of the set. Mine was limited to just the lower half and was held in place by nearly 20 screws. You don't need to remove all of them but do need to be able to open up the rear enough to access the connecter that sits on top of the upper left edge of the lamp housing. If you follow the two yellow wires from the white sensor, they track back to a small black connector with two black wires on the other side of it.
5.) At this point, you have removed the screw to the sensor. Now you will need to pull the connector wires free from the routing clip on top to free up space for the wire to move freely. Once these two black wires are pulled from the clip, pull the white sensor down from it's position to free it from it's housing and allow the yellow wires to be pulled from the left side of the housing out. If done right, the sensor is free now and can be pulled carefully by the connector at top and out the back of the set.
6.) Squeeze the clip connection where necessary and pull the clip assembly apart. The sensor is now free of the TV entirely and you can work with it separately.
7.) Grab a nail file and work the connector pins a little to roughen the contact points a bit. This is similar to cleaning the contact posts on your car battery.
8.) Push the male end of the clip firmly into the female end until it clicks and then push a little harder to be sure good contact is made.
9.) Do the reverse as done above to put it all back together again and power up!
10.) The message should now be gone.
Nov 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Lamp switches off
The problem could lie in the heat sensor that sits just inside the lamp housing area inside your set. Apparently the technician fix is to clip the faulty connector Mitsubishi used when assembling the set and replace it with a soldered connection instead. My fix is simpler and does not require solder. My TV is a 57831 model so it may differ from others but not much if so. Here is what I did.
Oct 01, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
