Question about HP OfficeJet 6210 All-In-One InkJet Printer
Hi My 6210 printer comes up with error message-remove and check black cartridge. It appears that some ink has leaked from the black cartridge but evenn replacing wth a new cartridge has not solved the problem-help please
    President:
  • 787 Answers
Try to clean the contacts on carriage with piece of cotton.In worst case the carriage unit may be defective.
Posted on Oct 05, 2009
HP officejet 6210 all in one...message is"remove
Hi Jim,
When you install a new cartridge, be sure not to touch the contacts, and make sure the contacts on the cartridge align with the contacts on the printer, and all packing tape has been removed. If the contacts on the printter are coated with dry ink, you should clean them with a cotton swab and distilled water. Dampen the swab and wipe off the dry ink on the contacts and let it dryt. Also, run the cartridge alignment on the new cartridge.
I hope this helps. Let me know if you need further assistance.
Randy
Feb 09, 2012 | HP OfficeJet 6210 All-In-One InkJet...
Printer cartridge
Try celaning the cartridge contacts as shown here (for a different cartrdige, but same principle). If this does not fix the problem you will need to contact your dealer of the edible ink cartridges for warranty replacement.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Sep 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Check Black Ink Cartridge Message
Clean the cartridge holder with ISO profile ..
Jul 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
Jul 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Printer cartridge error
Hi there Error 50c
There is lots this happens with the dell printers
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 25, 2008 | Dell A940 All-In-One InkJet Printer
PRINTING ERROR
I would not recommend you refilling HP ink cartidges.
Because no other ink cartridges can give you a better quality or value for you money.
Even if you call HP and say that you are using reffiled ink cartridges then they will not support you even if you are in warranty.
Because Genuine HP Cartridges are manufactured under SIX SIGMA Quality assurance and they give Value for you money.
What i can suggest you is to try a Geniune set of ink catriadges and check.
Good Luck
Sep 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer cartridges
Dispose of the leaky cartridge. Clean the contacts in the machine with a little rubing alcohol and a q tip (don't soak it-just moistened it a bit) Make sure the Printer is turned off while you are doing this. While you are doing this I will look up your cartridges and what they are for. I suspect that you have a color cartridge/a regular black cartridge/ and a black printing only cartride but I will check. Don't ever use a leaking cartridge they can damage your printer.
Aug 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
