Question about Epson Stylus D88 InkJet Photo Printer
IT CAN NOT PRINT EITHER IN BLACK NEITHER IN
IT CAN NOT PRINT EITHER IN BLACK NEITHER IN COLOR. i'VE CLEANED THE HEAD, I'VE CONTROLLED THE ENDINGS AND IT DOESN'T WORK. IT ALSO SOMETIMES CAN NOT TAKE THE SHEET.
    President:
  • 787 Answers
The print head of your printer may be clogged or in worst case defective.Look for specialist who can uncork the print head.
Posted on Oct 05, 2009
Epson picturemate photos printing all black
Maybe you set printer options to print color as black.
Aug 18, 2012 | Epson PictureMate InkJet Photo Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
I have canon mx310 which is telling me both color and black ink levels are low. when i print, only color prints - no black. i've also been told NOT to replace cartridges unless it says they're...
Check the cartridges, if empty then replace them.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 17, 2011 | Canon PIXMA MX310 All-In-One Printer
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
Cannot print black text
You need a new printhead, QY6-0059-000 around $40.00
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
I80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Apr 27, 2008 | Canon i80 InkJet Printer
Epson Stylus D88 InkJet Photo Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
