Question about Samsung (SP0822N) 80 GB Hard Drive
I just installed a new hard drive in a sony vaio computer. I am getting a message of "media test failure, check cable". In the bios boot menu, the hard drive is recogniized as samsung hm080gc - (PM) What do I need the Primary Master settings to be? I see no listing of cylinders, heads, or sectors on the label of the hard drive.
  • dawnhashley Oct 05, 2009
    To load default settings, just hit "setup defaults"?
    what is the bios set up for a samsung hm080gc hard drive? I keep get check media cable. That is not the problem. My bios setup seems to be the problem
  • 813 Answers
In case no cylinder, heads or sectors are being displayed, it means the fault with connecting data cable or the hard drive itself. Since the HDD is new, chances of it's being bad are less, so please try changing the data cable connecting the HDD to the mainboard and then check.
Posted on Oct 05, 2009
  • Samsung Master
  • 6,487 Answers
This can only be a problem still with the connection to correct this one unplug the drive abnd reconnect it back and also load the default settings on your BIOS ....
If you starts it, there is black screen with the message: media test failure
Go into the BIOS settings at boot up. Disable the option to boot from network, that must solve it :)
May 27, 2014 | Acer Aspire 5100 Notebook
Pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | HP Compaq Presario R4000 Notebook
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
Media test failure
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | eMachines T3604 PC Desktop
PXE-61: Media Test failure, check cable
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
Sony vaio
This fault is usually a disk controller problem/fault or the hard drive is not making proper connection or most likely the hard drive is faulty.
Try reseating the hard drive first.
If this doesn't work, check the BIOS to see if it detects the hard drive.
If the BIOS cannot detect the hard drive then remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and cannot open the folders and files, then the hard drive is confirmed faulty.
Install a new hard drive and install Windows on this drive together with the device drivers and programs to get a working laptop again.
Sep 09, 2009 | Sony Computers & Internet
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
OPERATING SYSTEM NOT FOUND....NO ACCESS TO CD DRIVE
Connect your external CDROM to the laptop. I think it is a USB CDROM. Enter your bios setup. In the boot device section, try to find any option which says First Boot Device -> USB CDROM. If you can set this things then the computer will be able to boot from your external cdrom.
Nov 26, 2008 | Sony VAIO GRX550 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Samsung (SP0822N) 80 GB Hard Drive Logo
52 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
