Question about Whirlpool GH8155XJ Microwave Oven
Door latch not functioning well
The door latch must be closed with some force in order for the microwave to close and operate. if it is closed gently, the inside light stays on and it will not allow it to operate.
  • 126 Answers
The door switch needs adjusting recommend a service tech to do this
Posted on Dec 22, 2007
Fan and light stay on when door closed. Shut off when door is open. Still heats. Door latch and spring are intact.
These door open or closed mixups are usually caused by the micro switches that are controlled mechanically inside by action of the latch when the door is closed/opened. There are usually 3 or 4 of those switches. Make sure the door protrusions are activating them. They can be replaced by generic ones of the same rating. I would replace them all! They cost less than $2 each. Order them online from a company like Mouser Elec or Digikey. You can test them for operation with the ohms function of a digital voltmeter. Be careful inside of a microwave. Deadly voltages even when off! Get some electrical help if you are unsure.
Nov 16, 2015 | Sharp R530E 2.0 Cu. Ft. Full Size...
I have a panasonic microwave genius protege type AP104A which will not always work after closing the door
Closing the door operates a switch or switches which function as an interlock to prevent the oven from starting unless the door is closed completely. The switch or switches may be defective or misadjusted. Also, the door may not be closing properly to close the switch(es).
Dec 07, 2013 | Panasonic Microwave Ovens
Door does not stay closed
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1660 spacemaker XL microwave
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Apr 25, 2010 | GE JVM1660 Microwave Oven
The latch on kenmore micro #721-62622200 is broken at bottom
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Mar 07, 2009 | Kenmore 62622 Microwave Oven
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave door won't close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Microwave Ovens
Whirlpool GH8155XJ Microwave Oven Logo
315 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
