Question about Acer TravelMate 342T Notebook
Acer travelmate 342t CMOS Battery bad, How do I
Buy turning on my acer travelmate 342t the following error massges pop-up:
CMOS Battery Bad
Real Time Clock Error.
How do I replace the CMOS Battery
    Sergeant:
  • 247 Answers
It is inside,on the motherboard,it is a watch type battery or a vinyl coated battery pack that plugs in the board,if it is the watch battery type,be carefull removing it.the holder can break off the motherboard very easy,might be able to get to it by removing the plastic piece above the keyboard that surrounds the power button,otherwise dissassembly will be necessary
Posted on Oct 05, 2009
I just replaced the battery in my 342t and it's pretty easy. Take a look at this video:
http://www.youtube.com/watch?v=dxtA6Jk6Ouk
The process is almost exactly the same. Remove two screws from the back, open the screen laying it out flat then use a small screwdriver to lift the trim piece between the keyboard and the screen (it just pops up but it's easiest if you start on the right side just above the + key). Once that bar is out of the way, the keyboard can be pulled forward toward the screen 1/4" or so to release it then folded back over the front of the laptop (careful with the ribbon cable). The battery is under the aluminum panel on the far right side of the motherboard. Only one screw holds it down but it can be a little finicky to remove since it's wedged among other body pieces. The battery is a cr1220 and is socketed so it's easy to replace. Reverse the process to reassemble.
Posted on Dec 05, 2011
Replace cmos battery
Hi, you can follow this steps: Just Go to Pag. 67, or you could just use this Time Sync Tool, you are only interested on have the time and date correct every time you use your computer.
Oct 16, 2013 | Acer TravelMate 330T PC Notebook
CMOS battery is bad
Replacing CMOS battery in Acer TravelMate 529TXV step by step: 1. remove all power sources (unplug cable, remove battery) 2. remove keyboard (carefully!!) by unsnapping it at the snaps upper and lower edge 3. in central part you see a metal cover mounted with 2 screws - unscrew those and slide the cower slightly downward (in the direction of the touchpad) to remove it. 4. You can now see a small battery, that is now very easy to remove. Take it to a nearest battery shop, buy one with EXACTLY THE SAME PARAMETERS! and reverse the whole process.
Aug 27, 2011 | Acer TravelMate 529TXV PC Notebook
When I start my TravelMate 527TXV, I have an error message for my "cmos battery bad" "Real Time Clock Error" & when I proceed to change my time in the Seyup Utility my computer...
go to this link http://www.youtube.com/watch?v=cg_wvp1YdSI The Battery # 2032 or can be smaller like a dime. to be sure buy the replacemente when you got the old one in your hand. You can buy it in Walgreens
Dec 23, 2010 | Acer TravelMate 527TXV Notebook
How do I do to find and replace the battery with a new one? Problem: CMOS battery bad. Real Time Clock Error. Best wishes Bengt Olson Sweden bengt.olson@telia.com
The CMOS battery will be beneath the keyboard and is usually a button cell, (2032 or 2025 size) 3 volts. Just north of the touch pad possition.
Oct 22, 2010 | Acer TravelMate 512DX Notebook
Cmos battery bad real time clock error
Is time to replace the battery. Is gone.
May 05, 2010 | Acer TravelMate 512DX Notebook
How to go the bios setup travelmate 342t acer
F2 - BIOS Menu and change Boot order to CD - 1st Boot Device
Jan 16, 2010 | Acer TravelMate 342T Notebook
Booting of CD Rom
If Your Travelmate comes with Preloaded operating system.You must have operating system Cd. If it is not u r not having operating system CD. may u r trying using driver and documentation cd.It is not a bootable operating CD.
2.if u r using right cd then go to bios setting select option cd as first bootable device.
if it solves u r problem
rate me
Jun 25, 2009 | Acer TravelMate 342T Notebook
Where can i find CMOS battery of my laptop ACER travelmate
You will have to turn it upside down and start removing compartments untill you find it. (As you did not give me the model of the computer I can't tell you exactly where it is)
The CMOS battery is located on the motherboard and it looks like a large watch battery.
Details on changing it is here: http://www.smartcomputing.com/editorial/article.asp?article=articles/2004/w1510/32w10/32w10.asp&articleid=24031
Have a great Day!
Jan 28, 2009 | Acer TravelMate 529ATX Notebook
How to replace mo on acer 342T.. cannot open motherboard out of
If you go to this site you can get step by step instructions on how to take it apart.Hope it helps.
http://htcwizardweb.net/node/2584
Jan 17, 2009 | Acer TravelMate 342T Notebook
Acer TravelMate 342T Notebook Logo
749 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
