Question about Baby Gear
I need rear seat centre fold down armrest for mk1 zodiac
I have found one through a friend but thank you for your promote response
Posted on Oct 06, 2009
How do i let rear seat down from the trunk keys locked in the car
didnt specify vehicle --generic answer --on most cars their is a release --on door --on floor by drivers seat -in glove box--as to rear seat release most are in trunk if seat does fold down --if non fold down then need to remove bottom seat either push down and back or unbolt then same with back part of seat
Dec 24, 2016 | Seat Cars & Trucks
Putting down armrest on rear seat honda stream 2006
operators guide lost. need help finding one??
Jan 20, 2014 | Honda Cars & Trucks
How do I remove folding back seats on 1997 bmw 328i
Remove the headrests (if equipped). Grip the lower seat at the front part of the seat and pull upwards to clear the clips(1), and the remove the lower seat.
Fold down the armrest and remove the bolts behind the armrest. The upper seat(backrest) is then pushed up, pulled forward and then moved either left or right out of the vehicle from behind the seat belts
Jun 29, 2012 | Cars & Trucks
I have a 2000 Bentley and I can't remove the rear set to pull the manual trunk release
If I am not mistaken, you have to remove the head rests, remove the bottom bench, fold down the armrest and remove the bolts behind it (Note: At the bottom, the bolts for the seat are held in by a clip... You just take a flathead screwdriver and pry it forward and it will then release. Make sure you dont let the seat-belts retract; it be difficult to get it back.) Typically, it takes about 2 hours to remove the seats. You will also need a metric set of Allen and Socket Wrenches to remove the bolts.
Nov 16, 2011 | 2003 Bentley Continental GT
I can't into my trunk there is something stuck therefore i need to fold down my rear seats and move it but i don't know how to fold them down I trie but i got nowhere
Be sure that your model has fold down rear seats...you should see the seperation around both rear seats...if equipped, the fold down release is located at the top corner of each rear seat...pull the lever up to release...if your model does not have the fold down option...you will need to remove the rear seat...remove the lower cushions first...look on the lower front of the seats for hold down bolts...second you will need to remove the top of the rear seat...hold down bolts are at the bottom of the top cushion...after removing the bolts (one each side) you need to push up on the cushion to remove...this will then allow access to the trunk...find the trunk latch and try to release by twisting the latch cable...Hope this helps...
Jan 20, 2011 | Pontiac Sunfire Cars & Trucks
How do I remove the back seat / backrest from a bmw 328IC 1997
Fold down the armrest and remove the bolts behind the armrest. The upper seat(backrest) is then pushed up, pulled forward and then moved either left or right out of the vehicle from behind the seatbelts.
Nov 15, 2010 | 1997 BMW 328
I don know how to fold my rear seat down in my 2002 chevy silverado 2500hd. I can make the bottom seat fold up but I want to bring the back of it down. Do I have to take out the seat all the way or is the...
The rear seat backs do not fold down in these trucks, the seat bottom lifts up to gain access to the compartments below but the seat back does not fold down. The only thing you can do is physically remove the rear seats.
Oct 16, 2010 | Chevrolet Silverado 2500HD Cars & Trucks
How do i remove the backseat in my thunderbird?
Rear Bench
(see Figure 4)
  1. Bearing down with your knee on the rear seat cushion, push the cushion rearward and disengage it from the retaining brackets.
  2. Remove the rear seat armrests if applicable.
Fig. 4: Pull the bottom of the seat upwards and pull out
  1. Remove the seatback lower retaining screws and seat belt bolts.
  2. Grasp the seatback at the bottom and lift it up to disengage the hanger wire from the retainer brackets.
To install:
  1. Position the seat back assembly so that the hanger wire is fully engaged in the package tray slots.
  2. Install the lower retaining screws and tighten to 13-19 ft. lbs. (17-37 Nm).
  3. Position the seat cushion assembly into the vehicle.
  4. Apply knee pressure to the lower portion of the seat cushion assembly. Push rearwards and down to lock the seat cushion into the seat retainer.
  5. Check the seat cushion to ensure it is secured into the floor retainer.
Rear, Fold-Down Seats
  1. Push the rear cushion rearwards, then lift to release. Remove the cushion.
  2. Remove the 2 lower retaining screws attaching the seat back to the floor.
  3. Lift up and disengage the upper clips of the seatback from the top of the folding floor.
  4. Remove the seat assembly.
To install:
  1. Position the seat back assembly and align the retaining hooks. Ensure hooks fully engage in slots.
  2. Install the two outboard retaining bolts, then tighten to 13-19 ft. lbs. (17-27 Nm).
  3. Lower the seat backs and install the upper retaining screws.
  4. Install the lower center retaining screw, tighten to 13-19 ft. lbs. (17-27 Nm).
  5. Install the rear seat cushion. Ensure the rear seat cushion front retainers latch properly.
Hope helps (remember rated this).
Jul 01, 2010 | 1994 Ford Thunderbird
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
