Question about Kyocera Office Equipment & Supplies
HOW DO I READ THE METERS ON THE KMC2525COPIER
HOW DO I READ THE METERS ON THE KMC2525 COPIER
    Novelist:
  • 157 Answers
Press System Menu/Counter Key,
Press Check the Counter,
Press Print Report, a report will print out with counts on it.
Press Close
Posted on Oct 05, 2009
Yard to meters
1 yard = .9144 meters
I am guessing that is not the answer you want but more like how to change the reading from yards to meters on your compact 800 measuring unit
read the user manual to find the mode button and select distance or yards and change to meters
no manual , download one from the web site for the manufacturer
Jan 24, 2017 | Heating & Cooling
What should the meters read
Volt meters read voltage Amp meters read amperage. Voltage should be 120/240 +/_ 5% Current will depend on size of unit.
Oct 15, 2014 | Electrical Supplies
Tuning opek hvu200 for 6/10 meters
I'd say, start with the instructions that came with it, or read them at the link below:
http://www.opek.com.tw/rimages/754/20090914162649_1.pdf
Jan 19, 2014 | Radio Communications
Chevy silverado ecm
There are OBD 1 meters and OBD 2 meters that read codes, if your car is OBD2 you need an OBD2 meter to read the codes.
Dec 21, 2013 | Cars & Trucks
My nikon dtm 322 does not read distance above 100 meters.
are you sure about your instrument setting? you try press button "MRS1" or "MRS2", hold around 1 second n 1/5. Then at monitor come out "Target","Const","Mode","AVE" and "Rec mode". At "Target", u choose "prism". Good Luck.
Dec 10, 2013 | Nikon Dtm-322 3" Standard Total Station
How do I read the meter on a Canon 3025 copier/
Hello colleenm,
The button that will display your meter is located on the operator control panel that is at your fingertips. Locate the large green START button. At about the 2 o'clock postion to the START button is the STOP button, orange colored. Now look "slightly higher and slightly to the right " and you will see a small "Counter Check" buton. Press it and the meters will be displayed. You will see at the top of the list a meter labeled "101".That meter tells you how many sheets of paper have successfully exited the copier regardless of the size of the paper. My company asks that we set the devices up so that they count 11x17 paper as 2 counts as it is basically 2 sheets of paper. The meters that will be listed below meter 101 are usually unused unless a technician has customized the meters that reside there as we do. I hope this helps. If it does , please let FIXYA know. :-) SPINAL
May 13, 2011 | Canon ImageRunner 3025 Black and White...
... Problem I discovered the
the dash panel has a printed circuit board incorperating the led lights,you will need to replace it.....if you havnt tried turning up the rheostat next to the headlight leveler control please do so..
Sep 02, 2010 | 1997 Audi A4
How to get a meter read
You don't, all Canon PC's (except PC 850) do not have counters (meters).
Nov 24, 2009 | Canon PC-950 Black and White Copier
Vestax pmc07 pro powers up, but no output through amp or phones????
most likely one or some of the op-amps are blown. you are using the right ac adaptor too? sometimes when underpowered it will give a low output. also are you getting a read out on the vu meters? if so then most likely the op amps. if there is no read out on the vu meters, it could be the input stage. have you also tried your mic and aux in too?
my suggestion is, that if its under warranty get it fixed.
Aug 30, 2009 | Vestax Pmc07pro DJ Mixer System
Canon NP 6050 Copier - number of copies
I would say that is not the correct meter. The meter is only 6 digits long, maybe 7 it's been awhile scine I looked at one. You probly have a meter of 0136012. There is only one hard counter / meter in the copier. It's not even the serial number?? Good luck
Apr 30, 2008 | Canon NP 6050 Copier
71 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
