Question about Freezers
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
  • 358 Answers
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Posted on Oct 06, 2009
  • christian nielsen Oct 06, 2009
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What temperture should i set my frigidaire digital display freezer to
Good Afternoon Friend,
I understand that you want to know the temperature to set your Frigidaire freezer. Recommended factory default setting is 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your Frigidaire status has changed successfully. If more troubleshooting is needed, please leave me your model number in your comment. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Does the green light on my freezer need to be on at all times and temp set to normal
I understand that you want to know if the green light has to be on at all times and the temperature set to normal on your Frigidaire freezer, model# FFU2124D. The green light will always be on. This is letting you know that there is power going to your freezer. You do not have to leave to temperatures set on normal. You are able to choose any temperature that works for you and keeps your food frozen. When changing temperature settings, turn the knob slightly in the direction you want, and wait 24 hours for temperatures to stabilize. If you want to change the temperatures more, again wait another 24 hours after changing them, for the temperature to stabilize. Hope this is helpful.
-Best Regards-
WP
May 22, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
My upright frigidaire freezer is set on -1 degrees, but the display on the front indicates the temp is 8 degrees. It has gone as high as 11 degrees. Does this mean it is defrosting or is there another...
Hello swanee3669 - Have you trying measuring the temperature inside the unit to confirmed that it matches the display? If so, I recommend contacting a professional to accurately diagnose the unit since it sounds like it could possibly have a bad sealed, thermostat or control board.
Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What temperature shoud it be on please - it has from 1 to 3
I would suggest setting it on 2. But to eliminate guessing, the dial should be set so the temperature in the freezer compartment is 0 degrees F (-18 C). The best way to ***** this is to put a thermometer in the freezer and adjust the dial until the temperature is steady at 0.
Charlie
Mar 16, 2011 | Candy 2.5 cu. ft. / 71 liter Upright...
Need a manual for 253-9284215 Kenmore Upright Freezer
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Oct 06, 2010 | Freezers
Temperature
Recommended temp for a freezer is -17C. That's MINUS 17 degrees Celcius.
Usually the higher the number the colder the temperature.
Oct 21, 2008 | Freezers
Freezer cycling on and off rapidly
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
May 14, 2008 | Freezers
Kenmore upright freezer
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Apr 09, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
1,058 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
