Question about HP w1907 LCD Monitor
My HP w1907 monitor less than a year old is turning pink!
I have an HP w1907 monitor less than a year old - so still under guarantee - the screen of which has started to flicker and turn very pink intermittently. Is it about to fail and should I dismantle the system and take it back to the seller? Or have I just loosened a plug somewhere....
  • HP Master
  • 32,281 Answers
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
Posted on Oct 05, 2009
There is bright green vertical line occurred on middle of the screen
I am afraid your computer's screen has a defect. You should apply to nearest service. If your computer is still in the guarentee period thats fine. There may be exists different guarantee conditions for LCD screens, (death pixel guarantee) and some brands give this against even 1 death pixel. You have lots of death or distorted pixels (a line). Do not lost time and apply to your vendor.
Regards.
Aug 24, 2010 | HP w1907 LCD Monitor
A center line on hp w1907
you need to change the monitor...
Feb 26, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor will not switch on
your monitor could possibly have a backlight problem.. the wires to the lights are known to come off the lights in the screen.. if you try to check it your self be careful the lcd screen and lights are very frigile, nad can brake easly..
Oct 08, 2009 | HP w1907 LCD Monitor
Red lines on hp w1907 monitor
this sounds like pixels have died on the screen there is no cheap fix for this, its cheaper to buy a new one. if it is still under warranty bring it back as the manufacturer should cover this
Aug 07, 2009 | HP w1907 LCD Monitor
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
May 20, 2009 | HP w1907 LCD Monitor
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
409 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
