Question about Kenmore 73952 Gas Dryer
Kenmore dryer, saw igniter heats up, seconds later flame came out, started heating up then 4 to 5 minutes later flame and igniter sthut off,
    President:
  • 1,304 Answers
Sounds like bad gas coils the hold or assist, but i would change them both at the same time
they are the lilttle cylinders on top of the gas valve
Posted on Oct 05, 2009
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Kenmore model#110.72702101 starts up,heats then burner stops won't relite
If what your seeing is that the flame starts out and goes off and a few later later the igniter glows but no flame??? then the cause of that is going to be the coils on the gas valve are weak and not opening. This tip i wrote explains what is wrong when a gas dryer starts heating but after a while wont heat. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 13, 2011 | Kenmore Dryers
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
Heats for only 10 minutes the will not heat again
Your ignitor is going bad , Yes it sounds crazy, but this tip will explain further..
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Maytag SDG4606A Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
My kenmore model 70 wont heat. I replaced the coils, and gas sensor. the unit has been thoroughly cleaned. the igniter is heating up, the gas will light, then goes out a few seconds later. the unit is a...
Hi, Make sure the 4" vent is clean al the way outside. Make sure the vent hood in the wall is open. It sounds like the heat is short cycling do to poor air flow.
If the vent does not appear to be an issue, Watch the ignition while running and see if the ignitor glows later in the cycle and shuts down before the flame ignites. If this happens, you will need to change the coils on top of the gas valve. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | Kenmore 63942 Dryer
My kenmore dryer will start and run when cold after it heats up the flame (gas dryer)goes out then after 3 or 4 mins. i can see the igniter light but will not start a flame after 5 or 6 seconds the igniter...
gas valve coulkd be bad if not opening after a certain period of time the ignitor will turn off and attempt a few times more,does it have a soilenoid valve also open and clean any carbon that might be built up over yrs
Jun 21, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer not heating
You will have to replace "BOTH" of those gas solinoids. First, be absolutely sure that you "TURN OFF THE GAS". Then be sure the unit is unplugged. Remove the phillips head screws, remove the small metal top bracket, and slide the coil up and off. Then replace the coil, rehook your wire, and replace the metal holder. Upon testing, be sure to turn your gas back on. The first time it may act like it wont start, but let it cycle through a couple times to remove air. Good Luck And Be Safe. Jim
Sep 07, 2007 | Kenmore 72062 Gas Dryer
Kenmore 73952 Gas Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
