Question about Samsung LW15M13C 15 in. LCD Television
Samsung lcd tv
Well not power up fuse ok power to end of cable samsung lw15"e23cb
4 Suggested Answers
SOURCE: No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Posted on Jul 15, 2009
  • 5138 Answers
SOURCE: channel 7,72 &73 pixelate on
What is the Model# that is printed on back? If you only have 3 channels that do that its because the stations are not putting out a strong enough signal for the TV to complete Picture ,Its like having an antenna where as some channels will come in Good and Clear where as other channels wont because they are getting a weaker signal.
Posted on Nov 09, 2010
  • 134 Answers
SOURCE: Due to electric power problem
Yes. The TV has a solder in 4.5 amp fuse. BUT most of the time when the power surges it also shorts the Bridge rectifier assy. IF you are not familiar with solder techniques, you will have to replace the power supply board. SHOP jimmy has in stock. Use model number .
Posted on Feb 18, 2011
  • 66400 Answers
SOURCE: Sony KDL-40V4100 40" LCD TV
After the first switch ON and automatic switch OFF, do the standbylight at the front panel lit permanantly or is it blinks? If it blinks how many times? These blinking are if any, is the fault indications of the set, and with that number of blinks I can reach to the faulty secion inside and can give advice you to get it repaires. If it stayl lit permanantly of switches OFF along with; whatever be the status, inform me by FixYa comment box. OK.
Posted on Jul 15, 2011
0 characters
1 Points
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ... > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Flat Panel Televisions
I have a samsung le46m51b no picture just audio
Tcon board failed check the fuse on the board marked by the letter P on it check it is ok no screen can be the fuse has popped this works in milli amps. if a failing capacitor on main board or on power board it blows the fuse in the tcon board in the middle of the screen back you need to take all boards out and remove the cage mind the cables when doing this. unscrew the 4 screw on the silver case covering the t con board un clip the cables off the screen ( with finger lift the black/brown flaps from cable end up) carefully remove the cables from the tcon board, now looking at the tcon board you will see a row of resistors and one marked with P on it check this. using a meter. should read no resistance and if on buzzer on meter should buzz. if don't buzz, remove the fuse with soldering iron, replace with the same fuse from a nintendo ds they are the same blow rate. before turning on the tv when you put everything back check the capacitors on power board the 16 volt 1000uf check these for damage as this is one of the main areas to cause the tcon board fuse to blow. also on the main board there are 3 capacitors 2 the same size and one that stands up more check these as the power goes to these first before going to the tcon board side. you need to remove them to test them. if any problems with these replace them. when replaced and you have checked there is no faults you can see on any board then turn the tv on. should be fine then.
May 05, 2012 | Samsung LE46M51B 46 in. LCD Television
After purchasing a PVR machine from Shaw cable, our Samsung series 6 51" LCD tv requires having the source output on HDMI3. Is there a way to change the " TV " button on the remote to...
We had this same problem on our Samsung 5 series. What we ended up doing was leaving the PVR plugged into HDMI 3 and renamed HDMI 3 to PVR. If you go to your source list and hit the Tools button (i believe its Tools) you should get the option to rename or give a nickname to a particular source.
Jan 10, 2011 | Flat Panel Televisions
Samsung TV doesn't turn on
There is problem with your power supply.First you check power cable replaced with another cable. After check cable is ok then there is problem in side your tv.It can check by opening your set back cover.After that check on power board there is fuse,capacitor or fet fautly. Note:Which part is faulty replaced with same number which is menstion on the part.
Nov 04, 2010 | Samsung LN40A550 LCD TV
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Mar 08, 2009 | Samsung LA55A950 55 in. LCD TV
No power but fuse ok
IF it is making a clicking noise it is the SUB PSU , the one that powers the embedded PC, there are 2 CAPACITORS on the PCB that will be domed at the top a 1000uf and 1500uf, they are on the secondary side , this is a common problem with this and the 460PXN (same psu) replace caps with higher voltage rating is my advice,!!! I did everything OK!!
Apr 25, 2008 | Samsung SyncMaster 400PXN LCD TV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LW15M13C 15 in. LCD Television Logo
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
