Question about Panasonic KX-TG1100 Cordless Phone
How to turn off ogm function? - Panasonic KX-TG1100 Cordless Phone
    Problem Solver:
  • 11 Answers
This modell have not has this option
Posted on Oct 05, 2009
I need to set greeting on mfc-990cw
Press Menu and then use the up/down arrows to highlight Fax. Press Fax and then use the arrows to display Setup Msg Ctr and press that. Navigate to OGM and press that. Select F/T OGM (for announce only) or Msg Ctr OGM (callers can leave a message). Press Record OGM and then speak clearly to the microphone and then press Stop/Exit when done. The message should play back. Press Stop/Exit again. Then press the Message Center button on the MFC-990CW to activate the feature. (The icon on this button looks like a house next to a down arrow.)
Brother has the documentation for this unit here: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc990cw_all&dlid=&flang=English&type2=-1 .
I hope this helps.
(when my message center failed to record a OGM, the flash memory had failed. It had to be replaced.)
Oct 14, 2012 | Cell Phones
How do I change my original message on the answer machine?
Which Uniden DECT 6.0 phone do you have? Uniden makes several models.
For one Uniden phone that I know (DECT-1080), first make sure that the answering system is on. If needed, at the base press Ans On/Off. From a handset, press Menu/OK and use the redial and Phone Book keys to navigate through the menu to AM Operation. Press Menu/OK and navigate to Ans Settings. Press Menu/OK and navigate to Answer On/off. Press Menu/OK and then choose On and then Menu/OK again.
To set the Out-Going Message, again go to the Ans Settings submenu at the handset, and navigate to Record OGM and press Menu OK. Select OGM 1 or OGM 2 and press Menu/OK. Record your message after the tone. To select the OGM message to be heard by incoming callers, navigate to Select OGM, press Menu/OK, select the message and press Menu/OK.
Please note that you also need to make sure that the system isn't set to Announce Only in the Message length section. Enter this submenu from the Answer Settings as above. The choices are 1 minute, 4 minutes and Announce Only.
You can also do set the OGM from a touch tone phone remotely. Press * as the OGM plays and then enter your PIN. Press 06 and then 1 or 2 to select the OGM to edit. Then press 9 to return to the main menu.
However, on the DECT-1480, you set the OGM from the handset but in a different combination. Press Messages/Mute then 5 (or wait for the announcements to end). Press 8 or press the Caller ID/right arrow to navigate through the menu to 8: Record New Greeting. Press Menu/Select. Wait until you hear "Record greeting" then speak your message normally. Press 8 to end and listen to the playback of the greeting. Press End to save the message. (Select the desired greeting by pressing 6 instead of 8.)
Most Uniden DECT phone manuals are available from the product page or this list: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .
If you provide your model number in a comment, I'll be glad to give you the specific directions for setting the OGM on your phone.
I hope this helps.
Aug 08, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do you record your own ogm on a Tesco ARC 402 ansa machine phone. I have a pre recorded message but want to change to a personal message
press PROG, use the up and down keys to select TAM (stands for telephone ansa machine) then select ANSA and Record, then OGM, then personal. The phone will immeaditately start recording so you need to be ready to speak, when you're done press the green phone/ok button to finish. then press the red button until you return to the main phone screen. now press the OGM button on the base unit and you should hear your OGM personal greeting.
Cheers
Oct 09, 2010 | Cell Phones
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Dec 07, 2009 | Doro 830R Cordless Phone
I have misplaced my manual for my ntl d5100. Could
make sure you turn your answer button on after some will turn off when you change options
Oct 06, 2009 | Lands Phones
NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Jun 11, 2008 | Cable_and_wireless CWD4901 Cordless...
No user manual
May 20, 2008 | Cable_and_wireless CWD4901 Cordless...
One.tel OT150
May 19, 2008 | Cable_and_wireless CWD4901 Cordless...
Panasonic KX-TG1100 Cordless Phone Logo
82 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
