Question about Garmin Forerunner 50
"LoBATT" stays on in TIME mode (doesn't flash) ?
Does this mean it is the Watch, Hearth Rate Belt or POD ? How much usuage have I probably got left?
Have used this for nearly 50 runs between 20-30mins only (i'm a beginner!) Although, I only got this warning after my first 1 hour run.
"lobatt" display is the watch battery. The foot pod uses the LED to indicate low battery and the heart rate monitor wont give a reading.
Posted on Oct 15, 2009
How do I change the time on my watch it's an adidas ADH6057?
First lets get the buttons identified. Electronic 4 button watches are probably controlled by the same chip. Top left is the light button. Going clock wise S2 (Stop/Start), S1 (Reset), and S3 (Mode). Press S3 button (lower left) 3 times.- Tuesday flag and seconds should flash. Press S2 and Seconds will set to 00. Press S1 one time, Minutes flash and advance by pushing S2. Press S1 again and Hour digits Flash and S2 makes them advance. Continue through Date, Month, Day. When finished press S3
Oct 01, 2014 | Adidas Watch ADH6057
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
HOW TO SET TIME FOR ADIDAS DIGITAL WATCH
Sep 10, 2014 | Adidas Mens Uraha ADP6013 Black Resin...
Adidas watch
Sep 03, 2014 | Adidas Adp6036 Sport Digital Furano MenS...
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Jan 07, 2011 | Adidas ADH1572 Watch
I have a g shock riseman g-9200, what does the letters PS mean(just to left of hour in time keeping mode, also is there any indication that i am getting a atomic time keeping signal?.......Thanks.....syd
PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
Jun 12, 2010 | Casio GShock Riseman AltiTherm GW92001...
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
Garmin Forerunner 50 Logo
167 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
