Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence problem as described by others like Avil.
My 60 inch Philips TV same model # has the same problem, collapsing from the top and bottom as described by others. I believe I have the right parts identified as described by Avil but I am not positive. The RET resistors, when I did a search for replacement showed to types, Horizontal and Vertical. They were listed as different part #'s and prices, but from what I can see on the circuit board they look the same. Are they the same? can I just order the cheapest ones and use them? If not which three are Horizontal and which three are Vertical? Any help in clearing this up would be most helpful.
  • rexberg Dec 23, 2007
    Thanks Troylove11 for clearing up that I need to replace the vertical RET resistors. I just don't know by looking at the board which ones are for vertical and which are for horizontal. Could you help me identify them?
    Genius:
  • 1,153 Answers
This would be your vertical, now what parts are you talking about?
Posted on Dec 22, 2007
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Screen appears to be bent at the top and bottom.
Ur convergence it dead.U know how to solders?Buy a convergence kit use what in that kit.Tries these Websites for parts.Tv repair World.com,Tvrepairkits. Tv shop will cost u $300.Repair by tv tech.
Dec 16, 2009 | Philips 60P8341 60" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Messed up
Probably the convergence board.
First, try resetting the TV by unplugging it for 30 seconds and replugging it.
Does the problem exist on both cable/sat and an external source like a dvd player/vcr?
Go to www.usasupport.philips.com and enter 60pp9200 as your model number - click on the link for the "Quick Start" Guide - read p 8 on manual convergence - if the manual convergence fails, then your convergence board is bad.
Mar 17, 2008 | Philips TV Tuner Video Capture PCI Card -...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Arches of words and top and bottom doubled with red words
Convergence mis-alignment = replace convergence amp IC's
Part # STK392-110 sub to upgrade STK394-160E. I use
Hitachi brand for no recalls.....................T.
Oct 31, 2007 | Philips 60PP9202 60" Rear Projection...
Convergence problem with philips 60 in.
depending on how old it is, it will either have a special menu (you will need to enter service mode to access it, need model number for that), or a panel in the back that you remove a few screws to gain access to. If it is the panel in the back, you will see about 20-50 little potentiometers, that have a slot in the top. Go to Radioshack, buy a TV alignment kit, stock number 64-2230. The pots will be in rows and columns, usually...and they should be labeled. Find the column/row for the red, and the pot for pincushion, which is the issue you are describing. With someone looking at the TV, and it on, turn that pot until the pincushion looks normal.
Jul 29, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
