Question about Umax NBAC-53880 Mouse
Pls provide cable color code details with pcb connectivity in mouse . there is four diff. color cable 1 blue, 2 green, 3 white, 4 orange
Orange/white--orange--green/white--blue--blue/white--green--brown/white--brown
Posted on Oct 05, 2009
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Switch to switch connection
in the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Jan 16, 2009 | PC Connection Cross-Over Cable (363003X)
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Cat 5 Issue you replied to
The color is not so important as the cable follow the same standard on both ends.
It has been my misfortune to find non-standard wiring in a facility, so long as they keep the relationship of the pins the same it will work, if the installer did not then you cannot trust any of the work and MUST either redo it all or have it all tested and certified by a cometent network cable installer.
568-B Wiring
Blue/White 4
Orange White 2
Green/White 6
Brown/White 8
568-A Wiring
Blue/White 4
Green/White 2
Orange/White 6
Brown/White 8
Apr 21, 2008 | Computers & Internet
Networking
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
329 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
