Question about Maytag PYE2300AY Electric Dryer
My 8yr old Magtag PYET244AYW dryer is getting worse...
On regular dry, the heating element glows orange 15-20 secs, turns off about 45secs, and the tumbler is turning ok, but clothes are not drying effectively. The lint trey is clean and the vent is clear. We typically have to run an average load 3-4 times. What should I check or replace? Des 15-20 secs sound right or could the thermostat be messed up? Thanks.
    President:
  • 1,304 Answers
Check the air flow at the exhaust,
you should have a good and steady flow while the dryer is running.
sometimes cloggs happen in the middle of the exhaust line
Posted on Oct 05, 2009
Kenmore 700 series dryer problems
This could be a few things. The first thing to check is your dryers vent, make sure its not clogged and check were it exits the house because sometimes nest are made in them. A clogged vent will prevent proper drying because the moisture can not escape and/or the heating element turns off due to overheating.
If the vent is clear, with dryer empty open the door and hold down the door switch (button that tells dryer door is closed) and turn on dryer, as its running watch the back area of drum were the vent with little holes is, within a few seconds you should start to see an orange glow in that area. If the orange glow starts then disappears within a few seconds it means your vent is clogged, if there is no orange glow at all then you have either a bad heating coil or bad high limit switches. I believe youtube has great how to videos on how to replace them, its not that hard if you have basic repair skills. Hope this helps you and your able to get it drying agian
Dec 23, 2013 | Dryers
Takes to long to dry. installed new heating element, new tstats and i noticed that there was a gap on the back gasket drum. this will allow air that is not heated to enter the drum causing a longer dry...
Worn gaskets will cause some extended run time, but 75% of the dryer problems I repair are directly related to improper venting. Check that first. Pushing air thru the clothes is just as important as adding heat. Vent connector in rear should be rigid metal or heavy metal flex. As short as possible with no kinks. An easy way to check vent is to look at element when dryer is running. Should glow soft orange, not red hot or white . Try it with venting attached and then removed. If element glows less brightly with vent off, then vent is restricted.
Jan 13, 2011 | Kenmore 500 6952 Dryer
When the dryer is running it has a orange glow in the back
If the orange glow is coming from the right hand side (as viewed from the REAR of the dryer), that would be the heating element. The element is supposed to glow, but not continuously. It should cycle on and off as the thermostats regulate the drum temperature based on your dryer settings. If you are experiencing any problems, such as longer dry times, or poor drying efficiency, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. This will make the dryer seem hotter than its supposed to be and eventually can lead to component failures and is the source of many fire hazards.
If the problem is not heating element related, please stop using the dryer and UNPLUG it. Remove the cover where the power cord is installed and ensure all the connections are snug and the wires are not burned. Post back and let me know if you need further assistance. I hope you find this information helpful.
Jul 04, 2010 | Roper REX4634KQ Electric Dryer
Wed5530 dryer. (whirlpool) I put a load of clothes in and it will take a couple of hours to dry them. I checked the heating element and it comes on but it looks like only partially (looking at it through a...
Have you checked the vent from the dryer to outside. One indication of a restricted vent is taking too long to dry clothes. To check, remove vent tubing from back of dryer and dry a load.
Mar 22, 2010 | Whirlpool WGD5300S Dryer
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Jan 31, 2010 | Dryers
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
Why has my dryer stopped working
Have you checked the heating element to see if it's bad? The easiest way to determine if it's bad is to turn the dryer on without clothes in it and let it run for about 30 seconds and then open the door while its running and if you see a orange glow then your element is fine if not then it's probably bad. If you don't see the orange glow then you'll need to pull it apart and look at the element and if it's bad you should be able to see a break in the metal.
May 19, 2009 | Hotpoint NBXR463EBWW Electric Dryer
My Electric Dryer's Heating Element Glows orange while in use
Hi. this is quite normal when you dry heavy items. the dryer has sensors inside the compartment that will sense cotton and wool garment. if needed, the thermal regulator will adjust the element to the appropriate range. If there is a problem, the electronic thermal fuse will blow. this is the safety feature that will trigger itself if a fire or over heating is sensed. Also, if your selector knob is set to a cotton or high heat mode, the element will normally glow intensively during this cycle.
Please rate and god bless.
Mar 19, 2009 | Whirlpool Dryers
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
136 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
