Question about HP Pavilion dv9000z Notebook
Hi i just want to know what will i do if my comouter crashed when i open it theres a blue scree appear that it says that my computer was shut down please help me thank you..
  • 4,281 Answers
It is because of your harddisk has bed indexing for fix errors on harddisk you need recovery disk.
Then boot your computer with recoverry disk.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option then set first boot device as your cd or dvd rom.Then save and exit.
Then put disk in rom then power up follow the porcedure on screen.Then choose recovery console then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk.
Then check if still same blue screen you need to repair windowes for that boot again with disk and choose repair windows option.
Let me know if you need more assistance.
Thanks.
Posted on Oct 05, 2009
  • 788 Answers
Power up your unit and keep hitting the F-8 key.
Next look for the phrase" last known good running. and mark that.
This should bring you back to a good working configuration.
If that works for you, reboot the unit again after it has settled down and you should have know problems.
Hope this helps you.
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
No system disk has been found, insert CD and press any key to continue. There is a black screen on my PC, no matter what CD I put in, or pressing any key, the message above just appear again on the...
this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Mar 31, 2011 | Computers & Internet
HI there...I replaced my CD-Rom with a Philips DVD8801 and connected it properly to my dell dimension 4600. i replaced the optical drive, hooked it up the same and set the jumper to MA. however, dvds...
two solutions:
1-boot your windows from "Safe Mode". then download and install a driver for your DVD Drive.
(sometimes windows crashes because of installing new devices like motherboard or CPU)
2-reinstall your operating system (OS).
it is rare that an OS Crashes by installing a new DVD DRIVE!
Jan 15, 2011 | Dell Dimension 4600 PC Desktop
My comouter first blanked out and opened and closed windows/programs and then went back to normal. It then did it again for quite a while until I finally did a hard shutdown. When I turned it on it...
Errors on the hard drive or corrupt files/programmes are the usual cause of that sort of erratic behaviour.
When you get it back start it up and as soon as you get into Windows, run CHKDSK/F straight away, the computer then will shut down, or you must shut it down. As you reboot it, it will be in DOS mode and CHKDSK/F will run and try and fix the errors.
If that is not succesful, start the laptop up with your Windows System Disk and choose repair system.
Hopefully that will solve your problem. If not, you may need to format your drive and start again with a new system.
Nov 20, 2010 | Acer Computers & Internet
How do i fix blue scree error tha reads stop:0x0000007E
is this a recurring problem. There isn't much you can do, usually a software crash causes this,
maybe defrag the computer, uninstall any unneccary software, run a virus scan, etc. Sometimes it just happens, if it happening all the time, there maybe a hardware problem, or you may need to restore to factory settings.
Jan 06, 2010 | Dell Dimension E310 PC Desktop
Computer crash
this is all happen to not properly shut down, if your read the problem from blue screen so we can identify it give you some instruction how to fix it. YOu know only one can repair this is a computer technician or expert.. but i think you don't have so maybe your the one going to do it, here's is a instruction: 1. Put a Bootable System Disk XP or Vista or etc. 2. Make a Bootable Disk run before the system comes up... 3. Follow the procedure which appear on the screen... then so on.
Jul 09, 2009 | Dell Inspiron 1000 Notebook
Sir every time I open my PC there's a blue screen appearing then it shuts down but sometimes when I log in it's OK and if I open any program the blue screen appears again then will shut down. What would I...
Hello my friend, regarding your problem do you have installed program or driver software lately before this blue screen appear? i guess the problem here is more on the memory dumping of your computer. either the latest installed software is not functioning will or  u have a memory device problem either to much heat or cause by some circuit problem that made the memory device problematic. the worst case here is to replace memory but for now try to check first if the memory is running well and stay in its standard cooling temperature. Or you can reprogram your computer.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
Dell computer blue screen saying STOP
Try installing the operating system or repairing the operating system.
Feb 22, 2009 | Dell Computers & Internet
Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
Aug 01, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Pavilion dv9000z Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
