Question about BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire
Only the tweeters (speekers in the front) are working..... so sound is comming out of the speakers in the doors and from the woofer...... also... i tried many other amps.....and the same problem.........maybe all the other amps are also bad......or maybe the problem is not from the amp at all.... please help thanks
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
What factory size speakers come in a 97 yukon
They vary. Most Yukons and Tahoes had standard 6" (or 5-3/4") front door woofers and 1" tweeters in panels on the door switch clusters in 2-door models, and in 4-door models, those plus an additional pair of 6" (or 5-3/4") 2-way speakers in the back passenger doors, and in 2- and 4-door models with the premium sound package, they also had 4X10 oval speakers in the rear roof by the cargo door(s). These 4X10's were 3-way speakers.
May 18, 2014 | GMC Yukon Cars & Trucks
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from partsexpress.com
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
Woofer doesn't work
sounds like the voice coil could be open or damaged. the woofer can be reconed. reconing replaces all the moving parts in the speaker frame returning to new condition in most cases.
cathy@speakerex.com
Jun 25, 2009 | Alesis M1-Active MkII Main / Stereo...
No tweeter output
sorry but if the woofers work you have blown the mids and tweeters
Apr 30, 2009 | Yamaha RX-V663 Receiver
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
Front door speakers
i found the service buliton on this problem straight from GMC, bulletin No. 07-08-44-008 this is a recall issue and you need to go to the dealer to have them resolve.. i was locked out of your other question please rate this with the other one you have up... thank you Dave
Apr 04, 2009 | 2002 GMC Yukon Denali
BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire Logo
182 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
