Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Problem?? fills, but does not drain or aggitate
    Scholar:
  • 196 Answers
When you run the machine is there a buzzing noise when it is suppose to be washing/draining.
Need to know this before continuing.
Posted on Jan 02, 2008
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Washer fills with water but will not drain and the aggitator is not moving either. Could the problem be a bad or stuck aggitator?
When the machine is ready to drain get the hose in the back and put it down either out the window or in the tub what ever is closer and the water runs out on its own
Aug 06, 2011 | Washing Machines
Kenmore 70s washer is failing to aggitate. it will fill and drain, but not aggitate
Does it even try to agitate weakly?
Could be a stripped agitator, bad wig-wags (Common term for the solenoids that control the transmission) a broken wire or the trans, itself.
May 22, 2011 | Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
