Question about Rinnai Water Heaters
How do i adjust temperture, I would like to make it hotter.
    President:
  • 267 Answers
You'll find all the information you need at http://www.rinnaiuk.com/download.htm
PDF's include schematics for all dip switches
Please note: you'll need to get the pdf that corresponds with the correct model you have.
thank you for using fixya,rate my answer
vijay
Posted on Oct 05, 2009
Make water hotter
adjust the tempo setting on the thermostat or fit new element/s to the hot water system
Dec 17, 2016 | Water Water Heaters
How do you adjust the temperture
turn the knob. really, the same knob that says pilot is also a temp gauge.
Mar 14, 2015 | Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
How do i turn up the water heater to get the water hotter
1) Copy following link for tank-type water heater.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add comment and say which type heater you have
Jan 03, 2013 | Water Heaters
Hot water is not
Which type and brand water heater do you have?
Is the water hot at the water heater?
You might have plumbing problem with crossover.
http://waterheatertimer.org/Crossover.html
Aug 17, 2012 | Water Heaters
Trouble adjusting the water temperature for the Grohmix. I cannot get much coldwater.
hi
does the water flow decrease when you lower the temperture?
is there a pump on it?
remove the thermostat housing,their should be a grub screw on the side.
pull the housing off the spindel.
turn the spindel anti clock wise.the more you turn the lower the temperature.
refit housing
turn shower on and test
more info is required if this does not solve the issue
Dec 18, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
My water is not hot
There are two access panels on the heater, remove screws to access it. They cover the upper thermostat and element and the bottom covers the bottom thermostat and element.
The top thermostat is the main one that has a reset button along with a dial to turn up the heat for the top element. A white plastic knob that you can use a flat head screw driver to turn to adjust.
Also you have one on the bottom to turn to adjust the heat on the bottom.
This is how you adjust thermostat's to increase to a hotter setting.
Jun 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do you turn up the temp rheem 40 gal warror class
remove access panels on side of water heater and the thermostat has a dail to adjust to a hotter setting.
Mar 30, 2010 | Rheem Water Heaters
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Does the atwood electronic Rv water heater have a temperature setting? Brad
NO. ITS FACTORY PRESET. YOU CAN INSTALL ANOTHER HOTTER T-STAT OR BUY A KIT THAT YOU CAN INSTALL TO ADJUST THE TEMP.
Oct 18, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
312 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
