Question about Canon PIXMA iP2000 InkJet Printer
Waste ink absorber is full. how to clear this
Cannon Pixma IP 2000 inkjet
Waste ink absorber is full. how to clear this issue.
    Scholar:
  • 81 Answers
Canon recommend that you need to bring the printer to your local service provider, canon will not provide Joe Public with the replacement parts as consumables and even more importantly they will not provide the software to reset the error message.
From what I can see there is a hardware routine type fix for the problem,
Try
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or
Try
1. Turn off the printer. And disconnect the printer cable.
2. Press and HOLD the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button, the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
If this hardware routine type fix works it is at best merely a temporary fix, and needs to be repeated on a regular basis to keep the printers running. For a more permanent solution you need to combine the fix with the more complicated task of removing the pads and cleaning them. This is where the whole process can go disastrously wrong, the ink is permanent and will stain hands, clothes and furniture if it comes into contact with them. Check out the info on this website and on your own head be it
http://www.neilslade.com/Papers/inkjetstuff11.html
There are a number of websites which claim to provide the software fixes however using these is a kin to sailing in uncharted waters, it is your own choice however I would be hesitant to recommend it to anyone especially if there are a few government secrets on your hard disk
My advice is to find out how much your local service center will charge you to replace the ink absorber, then decide whether it is worth the expense. And when it comes time to change the printer remember canon's have ink absorbers which need to be changed by a service engineer
For more discussion on this problem (and many of the hard ware fixes plus a few links to the software reset providers) see the forums on
www.fixyourownprinter.com
Posted on Oct 05, 2009
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
How to remove a waste ink absorber in a IP pixma
It remove only OEM software.Search www.canon service tools.com.
Dec 27, 2009 | Canon PIXMA iP2000 InkJet Printer
Where is the waste ink tank?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Error 8
Dear sir your problem is or E8 mean
Waste ink absorber full, or platen waste ink absorber full
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon Pixma iP90 waste ink absorber is full- HELP!!
Cannon Pixma iP90 waste ink absorber is full. The printer is not printing
Mar 10, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
354 people viewed this question
old marine
old marine
