Question about Epson Perfection 3590 Photo Flatbed Scanner
I tried uninstall and reinstall
I uninstalled epson scan and then reinstalled. It is still giving me the same error codes as before. Any suggestions
  • 205 Answers
I have been responding under your original thread. Please go look there.
Posted on Dec 22, 2007
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Error code 24
Hi There,
This error means
"The program issued a command but the command length is incorrect." This error code may also display as "ERROR_BAD_LENGTH" or as the value 0x18 .
There is no point in trouble shooting such errors they may reoccur so i would suggest you to uninstall the Drivers completely from the control panel and the reinstall.
Here is the link to download the drivers.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=72185&infoType=Downloads
Thank you.
Aug 16, 2012 | EPSON Stylus CX5000 Series
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I am trying to install Epson S20 Drivers but forgot to romove some old Epson C64 software prior to this. The old drivers are now claiming to be the correct ones and will now let me delete them. Can you...
HI,
All you need to do is install revo uninstaller software from :
www.revouninstaller.com
next after you install it you will see your old epson drives in that and just click on it and then click on Uninstall at the top click next the applications uninstaller will begin then you need to uninstall it.If it says that it cannot be uninstalled or gives any error then cancel it and then on revo uninstall again click on next it will scan for registry files then you need to check all bold registry items and then click on delete.Make sure you only tick bold items don't remove then ones which are not bold this will crash your pc.
After you are done with that then it will scan for left over files and you need to click on select all and then click on delete.That's all you will be able to reinstall new epson software.
Thank you
Aug 02, 2009 | Office Equipment & Supplies
My motherboard dose not support epson 1500 scanner it give code error
What is the full model of the scanner?
Try another USB port ,also uninstall and reinstall the software from the CD or download the latest driver for it and only plug in the scanner when the installation has finished.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=0010000#scan
Apr 22, 2009 | ASUS M2N-MX Motherboard
I cannot scan to windows xp from epson rx425 all in one printer
First switch off printer & uninstall everything including the printer drivers. Download the latest software from Epson Support site & reinstall. Link:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64
Jan 28, 2009 | Epson Stylus RX425 Multifunction...
RX500 won't copy
what operating system are you using and what is the specific error message when you attempt to uninstall the driver?
Apr 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Scanner wont scan
I have an Epson Perfection scanner and it has always worked perfectly. Then, out of the blue, it completely stopped working. I cannot recall the error codes, but the solution I found was to uninstall/reinstall. I still don't know what occurred to create the problem, but it has worked flawlessly since the reinstallation.
Good luck.
Dec 22, 2007 | Epson Perfection 3590 Photo Flatbed...
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Open Questions:
I have a problem with my Epson Perfection 3590 PHOTO scanner. I have used it successfully for scanning photos and documents, but finally found some negatives to try scanning, but it didn't wo I followed the step-by-step Scanning 35 mm Negatives instructions under Scanning Film and Slides on page 4 of your .PDF manual found at https://files.support.epson.com/pdf/pr359p/pr359ppg.pdf until step 5. Step 5 states, ""Slowly slide the film into the loader. Let go of the film when the scanner begins to automatically feed it into position," but the scanner did not begin to automatically feed the negatives. Instead, I used the grey manual knob located on the underside of the lid to feed the strip of negatives into position. I launched the Epson Scan software and ran a scan in Full Auto Mode, but it only scanned the underside of the scanner lid like a photograph or document. I next tried Home Mode. Under Document Type, the only options are: Photograph, Illustration, Magazine, Newspaper, and Text/Line Art. There are no Film, Negatives, or Slides options. So I finally tried Professional Mode. Under the Original settings section, Document Type is defaulted to Reflective, so I clicked the drop-down arrow to change it to Film, which is shown, but the Film option is greyed out and cannot be selected. Several times I tried unplugging and reconnecting the cover cable to make sure its connected tightly and examined the plug and port with a magnifying glass to see there are no bent or missing pins. The connection is secure, but the scanner lid is still unresponsive (for example, the Eject button has no effect) and the software still doesn't allow me to set the operation to Film. I then tried the following steps, but still no change: 1. Launched Epson Scan software 2. Under Professional mode, clicked on Configuration at the bottom of the Epson Scan window 3. On the Configuration window, clicked on the Other tab, and clicked on Reset All 4. Confirmed restoring of Epson Scan 5. Launched the Epson Scan program again to try scanning negatives, but the problem remained. I downloaded and installed the latest recommended driver from epson.com/support, but that didn't help either. An Epson tech support agent I spoke with over the phone told me it must be a hardware problem, but the unit is out of warranty, so I'd have to take it to the nearest service center, which is 20 miles away, and pay to get it repaired or buy a new one. I took apart the lid to look for any obvious issues like bad connections or blown circuit components, but found nothing unusual or out of place. What can I try next to fix this thing myself? Thanks!
Sep 29, 2014 | Epson Perfection 3590 Photo Flatbed...
Epson Perfection 3590 Photo Flatbed Scanner Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
