Question about RIM BlackBerry Curve 8310 Smartphone
My scroll ball won't allow me to scroll DOWN; I can scroll up, across right and left, but NOT down................
  • 416 Answers
Pop the silver ring off from around the ball and remove the ball assembly. Be careful cause the ring only has connections on three sides and you must start on the side without the "pins". just keep messing with it and it will come out. then clean the rollers up and make sure the flap connector on the bottom is clean and intact. That should do ya for now and should hold you for several weeks
pls rate this fix
Posted on Oct 05, 2009
2 Suggested Answers
garydillon
  • 42 Answers
SOURCE: The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
Posted on May 30, 2009
My blackberry ball doesnt scroll down,just up,left and right ecept down
Chances are it's clogged with dirt and other debris. I suggest using a Q-tip© lightly dipped in rubbing alcohol and run it around the ball and move the ball and just clean it off. That should help.
If not, the ball probably needs to be replaced
Nov 17, 2010 | RIM Blackberry Curve 8300
The ball won't press down anymore.
take a cotton stick and dip it in petrol and then clean ur mouse with that cotton stick hope it would work . . .well mine did !!!
Mar 23, 2010 | RIM BlackBerry Pearl 8100
Put on voiceover and cannot remove it, cant scroll down
I had the same problem. Just swipe your finger directly across the screen, left to right, over and over to eventually scroll down.
Mar 10, 2010 | Apple iPod touch
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Ball does not scroll down
the trackball roller pins need to be cleaned or the entire trackball replaced.
Jul 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do i delete several text messages at a time from my curve
If you have a section of say 10 texts or emails that you want to delete, get the first one highlighted them press and hold the aA button (bottom left) and scroll up or down to the end of the group you want to delete. Then press the Del key and confirm.
Jul 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
May 30, 2009 | RIM BlackBerry 8800
Scroll ball not going going down
I had the same problem and checked at the Apple store and was told to rub the scrolling ball with a alcohol prep pad. works wonderful. May have to repeat as needed.
Feb 21, 2009 | Apple Mighty Mouse Wired
Apple Wireless Mighty Mouse
Did you take the ball out and clean it and everything it touchs internally?? Dust tends to build up in it and makes it go where you dont want.
Nov 05, 2008 | Macally iMouse
Mighty Mouse won't scroll down
I have had the same problem on occasion.  I found that if I turn the mouse over and tickle it...  It works!  Only kidding...
Turn the mouse over, push down hard so the ball is depressed, and move it vigorously in all directions.  That usually dislodges whatever is trapped inside.
Dec 19, 2007 | Apple Mighty MA086LL/A Mouse
RIM BlackBerry Curve 8310 Smartphone Logo
1,004 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
