Question about GE DBL333EA Electric Dryer
Squeak The dryer makes an awful squeaking sound while running.
  • 55 Answers
It is proably the center bearing in the back of the drum, especially if it at least a few years old. It can be replaced by you if you are very handy.
Posted on Feb 11, 2008
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
My whirlpool (ggw9250pw3) gas dryer loud squeak
THIS SOUNDS LIKE AN IDLER PULLEY THAT KEEPS THE TENSION ON THE BELT. SECOND CHOICE WOULD BE DRUM ROLLERS.
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Loud squeaking brakes.
If they are wearing down, they may squeak, and some brakes have a metallic part that will come in contact with the rotor when the wear gets to a certian point making an awful squeaking sound telling you that mabe you should change 'em soon, eh
Jun 17, 2008 | 1995 Ford Escort
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Jan 06, 2008 | Dryers
GE DBL333EA Electric Dryer Logo
237 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
