Question about Nikon Speedlight SB-800 TTL Flash
Battery Corossion in my SB-800 speed light
Cant rotate left and right
  • 685 Answers
How o fix problem it just keep spinning on the floor
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
Feb 28, 2016 | Protocol Predator SB 3.5-Channel...
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
Oct 26, 2013 | Nikon Speedlight SB-22S TTL Flash
Ford focus.. the speed . rev counter. petrol and temp gagers on the dashboard keep going of and dont come back on.. then the dashboard lights flash everything goes on but back of again. any ideas please .
Check battery to motor and battery to body ground for corossion under bolts. Also check motor to body ground strap for condition and corossion. A bad ground can cause all kinds of problems.
Oct 13, 2010 | Ford Focus Cars & Trucks
go to any auto parts store and get a can of electrical contact spray designed to remove corrosion.
Oct 15, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon SB-800 flash won't rotate any more
Your flash needs to be opened.There is a small pin which must have got stuck. In SB 800 we need to open both upper and lower portions of the flash. If you are good at opening gadgets, just try with proper tools. Careful not to touch the main Condenser terminals. If you are in India, I can help you out. 09341932677
Jun 19, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon SB 800 fires but pictures reamain dark
    make sure your white balance is set to "flash" on both cameras
    Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon speedlight sb-800
    THE PROBELM COULD BE IN MAIN BOARD OR THE BATTERY CONATCTS NEED ADJUSTING
    Sep 22, 2008 | Nikon Speedlight SB-800 TTL Flash
    Nikon SB - 800 LCD Defect
    Impact has damaged the LCD assembly .
    IF you want it repaired contact the email address below
    Berrie Smith Camera Repair
    bbmw@bellsouth.net
    Oct 29, 2007 | Nikon Speedlight SB-800 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    152 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
