Question about Nokia 1100
No WIFI and no clock - Nokia 1100
WiFi authentication issues
Check the time on your computer's clock in the bottom right corner of the screen (on Windows). Is the clock and date correct? If they are not, then set them to the correct time and date. Hey presto, authentication problems on browser solved.
If your clock keeps needing to be reset every time you start up the machine, then your CMOS Battery is all used up inside the computer and must be replaced by a qualified professional.
Sep 23, 2017 | The Computers & Internet
How do I reset the clock?
You connect it to wifi the clock is set via the server the wifi is on anatomically
Mar 22, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Manual radio shack 63-170
the numbers 63-170 is not a scanner it is a clock here is manual for clock, if it is a scanner you need to give the model number
Mar 09, 2014 | Radio Communications
Wifi does not work
Check the wifi drivers first with folllowing steps.
Start-my computer -right clock and select the manage -device manager-select the network adapters -check the wifi driver if not plz download and installed.
You can see the wifi with this command use in run tab ncpa.cpl
Sep 10, 2013 | Computers & Internet
I have a compaq armada e500, how do I connect to wifi?
1.make sure you have a wireless network card first. (Originally this laptop does not have a wireless card with it so u need to get one first in order to get wifi)
2. u can get some usb wifi adapter here
3. just plug it in and you will have a wifi icon near the clock on your start menu.
Dec 20, 2012 | Computers & Internet
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
May 16, 2010 | HP Compaq nc6220 Notebook
I cant find my wep key
OPEN UR WIFI ADVISOR IT SHOULD BE NEXT TO UR CLOCK RUN IT AND CLIK ON ADD ANOTHER COMPUTER IT SHOULD GIVE U THE WEP AND NAME AND EVERYTHING U NEED. OR IF U DONT HAVE WIFI THAN THE PERSON U WERE GETTING IT FROM LEARNED HOW TO PROTECT THERE WIFI
Jul 04, 2009 | Nintendo DS Lite Console
ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
May 28, 2009 | Computers & Internet
Nokia 1100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
