Question about HP OfficeJet D135 All-In-One InkJet Printer
HP D135 PRINT error
My hp officejet d135 tells me the black ink is out (it's not) and then tells me I need to change the print head.
is there a solution for this problem? I seriously doubt the print head really needs to be changed, it worked fine up until now...
I use not original cartridges, never had problems before...
  • 3,600 Answers
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Posted on Oct 05, 2009
I have an hp officejet d135. It has knew ink jets and is hooked up. When I try to print the ink won't come out and the window says it's empty. Do I have a toner and if so where is it?
Your printer has a print head under the ink cartridges. You can try a cleaning, and if this does not fix the issue, you may need to replace the print head .
Clean Printheads function
To activate the Clean Printheads function from the front panel:
  1. From the front panel, press MENU.
  2. Press the RIGHT or LEFT ARROW until Status and Maintenance displays.
  3. Press ENTER
  4. Press the RIGHT or LEFT ARROW until Clean Printheads displays.
  5. Press ENTER
After a few minutes the HP Officejet D series will automatically complete the printhead cleaning operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP OfficeJet D135 All-In-One InkJet...
Can i substitute my color cartridge with a black cartridge. I am using a hp officejet D135. I may need to get a new printer but I can't test it because I am out of color ink and I don't want to buy one to...
No !!! First of all they are not the same size so the black cartridge most probably won't fit on the color slot, and if for any reason you need to print more with it, the black ink would have left its "mark" inside the color ink the injectors.
Jun 03, 2010 | HP OfficeJet D135 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp officejet d135
You can't, all carts must have ink in them
Feb 16, 2009 | HP OfficeJet D135 All-In-One InkJet...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Won't print in color
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
Jun 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP d135
Clean the copper contacts of the ink cartridge and the printhead wih the cotton swab and then try. Moreover in the printer there is an option to clean the printheads and ink carts. Later ty to print the h/w test page from the printer, if it prints fine then in the computer, righth click the printer icon and left click properties,in the color settings check if there is an option print in grayscale ... if thatoption is checked then uncheck the option.. and then print the test apge from the computer. If while priting the h/w test page it does not print in color then either upgrade the printer or replace the printer as the contacts of the printer ink carts slot are corrupted.
Jan 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
Print Heads
Make sure the printheads are not expired. Check the dates. Order new from HP direct
May 09, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
