Question about Nikon N2000 35mm SLR Camera
Electrical fault, no lights or other response when batteries are installed.
    Champion:
  • Nikon Expert
  • 225 Answers
Hi tjambarker, sometimes this is an issue with the battery holder. On my N2000 I had the same issue I needed to disassemble the AAA battery holder clean it then, it worked. Another thing to be aware of is on the camera the springs that hold the battery holder in place have two wires that go into the camera. If there was any battery corrosion it sometimes will travel up those wires causing internal camera corrosion. Off to Nikon it goes. You may be better served purchasing a used one for less than $90.
Posted on Aug 24, 2010
My 2000 jeep Cherokee sport it's not starting lights don't work, automatic locks don't work its not doing anything. What could it be?
If there's no response from any of the electric/electronic equipment, you may have a dead battery. You can check the battery with a multimeter (make sure you use the Volts range and connect the probes accordingly), you can also check it with a probe light or you can try to connect another car's battery with your battery using jumper cables (positive with positive, negative with negative) and see what happens. If the electric equipment starts working, don't try to start the engine for a couple of minutes to let your battery charge for a while. If there's still no response you may have blown fuses or fusible links.
Oct 16, 2014 | Cars & Trucks
What is the reason behind an intermittent electrical fault and engine failure
It is a difficult one to answer because it is intermittent and probably will not happen during a fault finding test. Intermittent faults in electrics generally are a result of bad earths ,rusted earths , loose battery terminals and cables into the terminals ,battery posts and terminals not shiny clean, loose connections in the harness, loose fuses holders and fuses harness connecters being dirty at the contact points and an electronic unit that has an internal (ECM) fault that occurs when the road is rough, bumps . For your problem I would be checking that all the connections into the ECM are clean and the connections are tight . Battery terminals and loose wires on the alternator. And one that happens sometimes ,heavy keys hanging from the ignition switch will sway back and forth and momentarily disconnect the run circuit. IT has been known to happen . So I think to be fair to the person doing the diagnostic check it would be akin to looking for a needle in a haystack while wearing brown coloured glasses. When it happens try to be aware of the exact circumstances at the time , how long the car was in operation, weather conditions (hot-cold), What you had working at the time (radio, lights , cigarette lighter, wipers what ever). Anything may seem unimportant at the time but may point to what is happening and so help the mechanic /electriciaan
May 07, 2014 | 2006 Ford Fusion
Apc bf250 will not power on
Did you charge the batteries before installing them?
Jun 27, 2017 | APC Back-UPS Office 250VA (BF250) UPS...
My xr250 (1997) has an intermitant electric fault where i loose all indictaors and lights i'm thinking it could be the stator what else could it be?
If you don't have a battery the lights will go off when the engine stops. If you have removed the battery you will kill the electrical system ( Very Expensive)
Sep 15, 2012 | 1997 Honda XR 250 R
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
Cummins verry rough idle no throttle response
HI
Thanks for the info!
Lets start from scratch and see if we have a mechanical or electrical problom Disconect the batterys both positve and negitve
let it sit for a 1/2 hour. Then hook the batterys up try and start it.
lets see if you get a check engine light or if wee need to go intothe mechanical end, Ill be here on and off most of the day
Thanks!
Jul 13, 2010 | 1998 Dodge Ram 2500 2WD
My car was having trouble starting, slow to turn, sometimes stalling out imediately after starting. Yesterday I went to start the car and it wouldn't start. Lights kinda flickered, but absolutely no...
check the earth lead connections to the engine from the car body, undo them, clean them up, and re assemble, then check the electric connectors to the starter motor the same way, check also plug connector is securely pushed into back of alternator.
Another thing to note, you mentioned the lights slowly dimmed after fitting new battery, this could indicate a major short circuit. good luck, P
Apr 28, 2017 | 2001 Hyundai Sonata
No power
Hi, I have the same problem with my FZ30. The camera just doesnt turn on. Even the battery when put in the charger, the light of the charger goes of in few minutes or few seconds without properly charging it. Can it be a fault of the battery or the camera itself?
Nov 07, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
Nikon N2000 35mm SLR Camera Logo
67 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
