Question about Kodak ESP 5 Printer
Where do u put the paper to print :) - Kodak ESP 5 Printer
  • bhadresh khatri May 11, 2010
    please your printer with scaner ?
  • 89 Answers
You put your paper in the print tray to fit into the guides.
Posted on Oct 06, 2009
Hello, well, I just got this printer, and I polugged everyting, and since I did not put the paper at the right place, it said that is has no paper. After touching every button, it as in memory my...
Easiest solution might be to cancel the print jobs... and turn off the printer. Then turn it back on after a few seconds and start over... see if that doesn't reset whatever has accidentally been set. (Oh and try removing the paper, then put paper in it again before you start the print job again)...
Good luck!!
:o)
Jan 04, 2011 | HP Computers & Internet
How can I print on both sides of paper?
Unless your printer has a "duplex" feature, you'll have to manually take the paper out, flip it over and put it back in to print on the other side.
Feb 26, 2010 | Canon Pixma MP500 All-In-One InkJet...
Lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Dec 09, 2009 | Canon LASER SHOT LBP-5000 Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Mar 27, 2009 | HP Photosmart C5580 All-In-One InkJet...
Printing Envelopes
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
