Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Makita core drill model8406
Drill will not spin round as if clutch has gone i need to get it fixed as soon as possible
    Problem Solver:
  • 14 Answers
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Posted on Mar 04, 2008
My Makita impact driver led light stays on soon as the battery is clicked in. Any idea whats wrong and how I can fix it?
the light is normally activates by the trigger, so either the switch has gone faulty or the wires running to bulb are contacting.
press the helpful button and check link below
Makita BTD142 Trigger Switch Replacement
Jan 23, 2016 | Makita Drills
Makita core drill. I have the 8406 core drill and when drilling a hole today, the drill suddenly seemed to lose a lot of power, it turns but not delivering enough rpm's to have an effect on the brick! the...
Sounds like it got too hot and burned the motor up. Had this with a making grinder. They are a piece of junk anymore. Hope it's still unber warranty.
Dec 26, 2017 | Drills
Have a new Makita DF330DW and the clutch started slipping out of nowhere. The drill will turn in fwd and rev but as soon as there's any resistance, it quits spinning. I have run it through all of...
Definitely a faulty clutch. Take it back to where you bought it (if it was recent), otherwise send it or go to a Makita Service Centre.
Hope that helps
Jul 10, 2011 | Makita DF330DW 108Volt Ultra Compact...
How do you remove the clutch on a makita 8406 have split the body so far ..thanks
How is the clutch removed from the makita 8406 core drill
May 15, 2011 | Makita Drills
My sds hammer drill gets stuck in really hard re-enforced concrete and carries on spinning as if it has a security clutch. trouble is itcome on much too often now. how can i adjust?
You listed an SDS (plus or max?) hammer drill (no model #) under Makita chain saws. I'm assuming you have a Makita drill. Most of them have torsion limiters that let the motor turn when the bit gets stuck so as to prevent major damage to the tool or user. If it has been going on for some time you may have worn out some of the internal parts. There are no adjustable parts to fix this, you have to replace the worn parts.
Aug 23, 2010 | Makita Garden
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
I HAVE TWO BROKEN MAKITA lxtbhp 351 z DRILLS. i
yes it is possible but you may find both gear boxs have gone in the same place it is a common problem with this drill gear box is £66
Oct 25, 2009 | Makita Drills
Makita 6349DWDE 18V Cordless Clutch
could be the clutch needs replaced, but I would check to make sure the high/low switch is fully engaged. Inside the clutch there is ring gear that could have the teeth rounded off I would go to Makitatools.com and type in your model number for a breakdown so you can see what you are getting into, they are not that hard if you are mechanically inclined and just watch how you do it.
Sep 23, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
814 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
