Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi 200w. will not turn on
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery must have been low because i had not used it. I have it plugged in, but nothing happens, its just dead, wont even turn on????
  • Harry
    Harry May 11, 2010
    Sound like a very low battery or a bad one: Make SURE you use a Garmin Charger.
    There are three ways to charge the internal battery in your automotive GPS
    unit.1
    Use the provided vehicle
    power cable that came with your GPS unit. The unit will charge while
    powered on and using the device as well as when the GPS unit is powered
    off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge
    in the vehicle, check the fuse in the power cable for the unit and
    the power outlet in the vehicle.
    Use an AC power
    adaptor. Some units come with this power cable to plug the GPS unit
    into a wall outlet allowing the GPS unit to take a charge. For units
    that do not come with this cable, one can be purchased from Garmin's online store.
    For most units, the final way
    of charging the battery is to plug the GPS into a powered on computer with
    a USB cable2. This
    method of charging will be a trickle charge and it may take longer (like a
    full day) than the other two options, however it will still charge the
    battery. A USB cable is provided with a few GPS models. For those
    that don't come with this cable, one can either be ordered from the online
    store or you can use a standard USB to mini-USB cable that fits the
    unit and plugs into your computer.
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on.
Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on. It is a very tiny button and hard to see. So look carefully!!
Posted on Feb 06, 2010
My Garmin Nuvi 200W, when I turn it on sometimes it failed and after few hours when I tried again sometimes it works
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 24, 2010 | Garmin nuvi 200W GPS Receiver
My garmin gps cannot locate a satellite
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Dec 13, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Dec 12, 2009 | Garmin nuvi 1300 Car GPS Receiver
SLow to acquire satellites after being turned on in the car
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Dec 07, 2009 | Garmin nuvi 200W GPS Receiver
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery...
If the GPS's internal battery is allowed to discharge too far, it will not be possible to recharge with the card charger, until it is brought up to a certain level. Connect the nuvi to a computer with USB cable overnight. This will trickle charge the internal battery to a level that will allow the car charger / cradle to keep the GPS charged from that point on. Anytime the car charger fails to recharge the internal battery, the USB charge method will have to be performed first.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
Lost satilite reseption
I hope that helps.
___________________
Oct 12, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200w
Found this thru Garmin support
Question: Why will my nüvi 2xx not find satellite signals?
Answer:
p>If your nuvi 2xx is not acquiring satellite signals, you may need to download and run our WebUpdater program.
Go to:
http://www.garmin.com/products/webupdater/
If you are still having issues after updating the software on your unit, you may need to do a full master reset. Please note that a master reset erases Favorites and waypoints. Before proceeding, you may want to back up information you want to keep.
To do a full master reset to the nuvi 200 series unit:
1. Turn off the device.
2. Place your fingertip or the eraser end of a pencil in the bottom right corner of the touchscreen.
3. Apply pressure in the bottom right corner of the screen.
4. While pressing down on the screen, power on the unit and continue pressing on the screen. A message displays to confirm that you really want to delete all user data.
5. Touch Yes.
6. Your unit restarts automatically. You must go through the set up procedure again.
Once you complete the reset, place the nuvi unit outside where it has a clear unobstructed view of the sky for 15-30 minutes. Keep it in a stationary position until it reacquires satellites.
May 20, 2008 | Garmin nuvi 200W GPS Receiver
Sesrching for satellites
Okay well have you tried to return the item and see about getting it exchanged for a new one and see if that one works, it's not uncommon for a product that goes down an assembly line to have a few of them that don't work. I would try there and if they don't do anything for you I would call garmin directly.
Feb 26, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
456 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
