Question about Video Game Consoles & Games
Fisher Price InteracTv
One Controller, DVD, Set up card, Test card, Quick Set-up Instructions, Users Manual, 1 DVD & cards for - Numbers Everywhere, 1 DVD & cards for - Wild Animals, and 1 DVD & cards for - iRapido, Tico!
I have a ProScan DVD and a ProScan TV set. After hours of trying to set up the controller to the DVD, I have only been able to turn off the DVD and the TV. Can't get to the test stage.
Please help! This is a Christmas for my grand child.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Need manual or help for Fisher Price INTERACTV controller set-up
Here is the setup guide
http://www.fisher-price.com/uk/interactv/pdf/setup_guide.pdf
cheers
Posted on Feb 16, 2008
  • 1527 Answers
SOURCE: we have a fisher price interactv
hello is it pluged into the front of the tv if so then just select av channel or it ext1 it should pick it up
shaun
Posted on Aug 01, 2009
I need to program the Fisher Price Inerac tv to the dvd and or the tv so I need the instructins on how to I lost the and the dvd it was programed to is broke, can you help it is about 7 years old. it says...
spacer.gifThe following steps will allow you to program your InteracTV controller:
  1. Make sure the InteracTV controller has good batteries. Slide the 3 position memory switch, on the back of the controller, to the desired memory position. The controller is capable of being setup for up to 3 different DVD players in 3 different locations.The controller must be setup and tested individually for each of the 3 DVD players, but once that is done the controller will retain the manufacturer's code and does not need to be setup again.If the consumer accidentally enters a new valid 4-digit manufacturer’s code, then they must set it up again for that DVD player.It is a good idea to write the 4-digit manufacturer’s code in the labeling area provided on the back of the controller.
  2. Insert the compilation DVD into the DVD player and turn on the DVD player and TV.
  3. Insert the programming card into the controller; the green light should blink twice.
  4. Locate the manufacturer’s codes in the user’s manual.
  5. Enter the first 4 digit code listed under the manufacturer. Use the right arrow button for the number. The light should blink after each button press and blink a long blink after the 4th digit is entered.
  6. Remove the programming card.The light should double blink when the card is removed
  7. Insert the test card into the unit;the green light should double blink.
  8. The DVD should skip to the test screen, if it does not, repeat from step 3, choosing the next manufacturer’s code on the list. If the test card skips to the footage, which resembles the test card, then proceed with testing the unit.See Testing the unit section of you manual or quick setup instructions.
  9. If you have tried all of the manufacturer's codes listed and you cannot locate an acceptable code, see programming the unit using manual search in your user's manual.
You also might want to check this site for full product support:
http://service.mattel.com/us/product_detail.asp?id=B9376&Ntt=B9376&Pn=1&Brand=Technical+Products&Cat=InteracTV
Hope it helped.
Nov 15, 2009 | Video Game Consoles & Games
Interactv
i presume there are av cables, so i'd say plug them in and turn the tv to av mode(somewhere on your remote control you should see and a.v button) press it mutipule times until you get to the right channel and the device should display through the tv
Oct 18, 2008 | Video Game Consoles & Games
I have a fisher price Interactv and no programming to dvd instructions for it, I need the instructions to program the interactv to dvd so my child can use it with her dvd. thank you in advance. I have a...
You will require the blue programming console card and the yellow console test card plus the original dvd which has dora, elmo and sponge bob.
A word of warning, we tried to get this system working on our daughters cheap "no name" dvd player and couldnt program it even manually. I contact Fisher Price who advised that it would generally only work on "mainstream branded" machines.
I have the instruction manual, which contains the codes to program to your dvd player if further help is required email me at jcandvh@gmail.com The manual programming method is as follows
1. Remove Interactv DVD from the dvd player and using the dvd remote power it off
2. Insert the blue programming card into the interactv console and ensure the the green light blinks twice
3. Direct the console at the dvd player and slowly press the arrow button on the left hand side of the console until the dvd player powers up. BE PATIENT!! There are heaps of codes that the console runs through so this can take several minutes.
4. Once the dvd player has been powered up by the console, stop pressing the left button, insert the dvd into the player and it will go through the introduction and then bring up the screen which shows the programming card. The tv will then say, if you have already programmed and tested insert game card, otherwise insert the yellow test card and follow the instructions on the tv. Again, when you insert the test card the green lights will blink twice to indicate that it has been inserted correctly. If you have managed to get the console to get the right code for your dvd player, it should bring up the yellow test card screen automatically. If the test screen does not come up, the correct code hasnt been picked up by the console even though it turned on.
Alternatively, you can contact InteracTV Helpline on Australia 1300135312
Oct 12, 2008 | Toys
Mattel Fisher Price InteracTV consol game
There is a set up Card and programming Card that you need to use in order to get the game working you don't need any code. If it doen't work you can call to Mattel-Fisher Price they have a very good customer service line. Let me know if you need more help. Good loock!!
Apr 06, 2008 | Video Game Consoles & Games
How to program fisher price interact tv with our dvd; do not have instructions
Here is the link for manual. It comes in five little documents. If you need the whole manual download all five. Just takes a minute. Otherwise just click on each one until you find the one you need. http://service.mattel.com/us/product_detail.asp?id=B9376&Ntt=B9376&Pn=1&Brand=Fisher-Price+Technical+Products&Cat=InteracTV
Mar 15, 2008 | Video Game Consoles & Games
You can get them at the fisherprice site. Heres is there faq and help section which can be useful to you and your husband.
http://www.fisher-price.com/us/interactv/faq.asp
Dec 09, 2007 | Video Game Consoles & Games
Video Game Consoles & Games Logo
82 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
