Question about LG Vu CU920 Cellular Phone
Battery will not charge correctly. When I plug it in, it says it is charging but it isnt actually charging because it never gets the "battery complete" stage anymore and when i take it out, the battery only lasts a couple of hours. Also, the phrase "connecting as music sync" pops up every once in a while when its charging... please help!
I have the same issue. I found out its because Im using a generic charger. If your using a cheapy try buying a OEM charger. That should fix the problem. Im trying to figure out a way around it. Will post back if I find anything.
Posted on Nov 17, 2009
  • rshinkle484 Nov 17, 2009
    Go to menu, more, settings, connections, USB Connection Mode, then choose Data Service. Worked like a charm for me. Hope that helps.
New battery not charging
Some aftermarket batteries don't play well with your Laptop, the "pin-outs" may not be correct. Be sure to buy a genuine Dell replacement. I have no idea where you purchased it, but inexpensive replacements found on-line can be a problem, and, at best, will not work correctly, worst case can be a fire hazard. Return it and find another.
Mar 30, 2013 | Dell Inspiron 4100 Notebook
Camera shut down
Hi the problem your having is that a component on the board isnt letting the correct power come from the battery therefore giving false reading on the batt display the huge problem you have is that they dont repair these cameras it just isnt financially worth it so unless you know how to test all components on the board the chances of getting it reapired are slim to none their isnt anything you can do as it is a board problem.
If you tested the battery and this is fine then the problem is deffinately with the board.
How long have you had the camera if its not long then i would get a refund as repairing is something they wont do sorry i couldnt help you any more but other experts will tell you the same
Feb 05, 2008 | Konica Minolta DiMAGE X1 Digital Camera
I have a 1984 Ford F 250 that I changed the alternater and battery in. Its not holding a charge at all and its back firing as well. any ideas what could be wrong?
the only three things i can think of is youve either got a bad alternator ( yes if its a remanufactured one its possible) your battery is wasted (replace), or the wiring isnt correct and the alternator isnt providing to the battery.
Nov 23, 2012 | Ford Cars & Trucks
Bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Feb 24, 2012 | RIM BlackBerry Bold 9000 Smartphone
Battery light on
is the alternator charging? check a single tiny cable plug going to the alternator if it is not plugged right it could make the battery light flicker or simple turn it on. that little wire receives a signal from voltage regulator if alternator isnt charging correctly.
Feb 20, 2011 | 1995 Ford Taurus
I have a Acer laptop and I just bought a new charger for it because I thought that the old had stopped working but the new one isnt working either. The computer says that it is plugged in but not...
Hello:
Maybe your battery is ruined. Batterries tend to lose their capacity after a year or two. It depends on its use and care. If your battery is too old, for sure, you need to replace it.
I hope this helps. Thanks.
Jan 31, 2011 | Computers & Internet
Why I Get Warning battery light on a new Battery
You may have a bad alternator, when the alternator isnt charging this will also turn battery light on, have the cars charging system tested, this will tell you if the alternator is charging, hope this helps.
Oct 29, 2010 | 2002 Honda Civic
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
Coby TF-DVD7006.
The second question, I couldnt work that one out at first, but now i think I understand. If you plug the player into the mains, turn it on, red light shows. Light turns green when battery charged. Do not use until light turns green (if plugged into mains). In other words dont use the player while the battery is charging. If it isnt plugged into the mains then the battery cant be charging and you can use. Until battery gets too low :)
Nov 13, 2007 | Coby TF-DVD7006
LG Vu CU920 Cellular Phone Logo
123 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
