Question about Sharp LC-32P50E 32 in. LCD Television
Default to EXT4 after switching on Sharp LC-32P50E
When the TV is switched on it defaults to EXT2. I am using a SKY HD decoder using the HDMI connection on EXT4. Is there any way to get the TV to default to EXT4?
4 Suggested Answers
  • 362 Answers
SOURCE: default input when turning on the TV
From the menu select Option, then select Input Select, then select the signal type you want to use on startup, set to Auto, then press menu to exit. let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 12, 2009
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 15, 2009
SOURCE: sharp aquos LC-32p50E
I too the tv to a repair shop and they replaced the switch. It cost £70.
Posted on Feb 27, 2010
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Ive had sky hd fitted today and cant get sound on tv hd settings but can on normal sd
Hi it is entirely possible that the sky decoder has not been setup to output sound to HDMI. I assume you are using HDMI lead and this lead goes from decoder to TV.
Aug 13, 2010 | Televison & Video
Sharp lc32p50e, picture keeps freezing, sound ok. text hold symbol appears at same time as text freeze. any ideas?
try using the menu, and turn off the 'demo' mode ... this by default has a freeze setting .... hope that works
Feb 23, 2010 | Sharp LC-32P50E 32 in. LCD Television
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Jul 19, 2009 | Televison & Video
Can I set the default input?
some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Jun 14, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos LC-32p50E
Nov 28, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LC-37D4U 1080i picture problem
have the cable company set the box to 720p whic is the native resolution of the set.this will help with quick signal adjustment
Dec 29, 2006 | Sharp LC-37D4U 37 in. LCD Television
Sharp LC-32P50E 32 in. LCD Television Logo
111 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
