I need the jumper setting for mode 2l51536H - Computers & Internet
    Sergeant:
  • 244 Answers
You don't give much info to go on- but if you are adding a second hd and have your os on the existing hd, then you should set your second on 'slave'. there should be a label on the hd showing you where to set the jumper for 'slave' mode. make sure it's connected to the same cable as the other hd. 0n the second connector!
they have their priorities!
good luck!
Posted on Oct 05, 2009
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
I want to know the Jumper settings (Master and Slave) for IBM Travelstar 15 GB Hard drive. I would be glad and thankful if you will solve this problem for me. Ari Kiviharju
This solution will reference the picture below:
To configure the drive in Master mode, no jumper setting is used (Figure A1).
To configure the drive in Slave mode, the jumper must be placed over the two vertical pins on the far right (Figure A2).
To configure the drive in Cable Select mode, the jumper must be placed over the two pins in the bottom row (Figure A3)
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Computers & Internet
How do i program the jumper and the switch
the jumper settings is 1 and 2 is default. 2and 3 is normal mode. without jumper it reset mode for CMOS jumper settings. which switch do u mention? let me know
Aug 22, 2010 | Gigabyte GA-6VXE7+ Motherboard
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Oct 06, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I need jumper setting for a Maxtor Mode. #
http://search.seagate.com/wwwsearch/www3search.jsp
Try this site, just locate your paticular model number for diagram. Hope this helps.
Aug 17, 2009 | Maxtor Computers & Internet
How to reset passcode, copier given to the church. Ricoh Ft 5535
This will require a tech familiar with this machine to reset. The user code option is enabled by both a setting within service mode, and a jumper being disconnected on the motherboard of the copier. This jumper will need to be reconnected and the settings changed within service mode.
May 23, 2009 | Ricoh Office Equipment & Supplies
Using master, slave or cable select jumper
89c8602.gif SETTINGS:
A - Cable Select Mode
B - Slave Drive Mode
C - Mater Drive Mode
Enjoy!
Mar 01, 2008 | Lite On (LTN486S) Internal 48x CD-ROM...
Motherboard Jumper free code
Set Jumper Free Mode (manual) and new FSB in BIOS Setup - menu "CPU External Frequency (Mhz)".
Oct 24, 2007 | ASUS P4SP-MX Motherboard
Need help to set-up fcpga processe on asus P3V4X with asus-S370-L
Hi Neel, Are you running the board in JumperFree Mode? If so you shouldn't have to change any jumpers or dip switches. And the S370-L adapter card should NOT have to be set either, it should auto detect both processor core and voltage. If you don't know how to set the board up in JumperFree Mode let me know I'll walk you through it. If you ARE running in JF Mode then I'd contact Asus support. http://support.asus.com/ You have the right BIOS update to be able to support that proc but Asus had some issues with Intel chipset support with certain versions of the 370 adapter cards. (issues with both the S370-DL and the S370-L if I remember right) Let me know what happens, Dude
Nov 25, 2006 | ASUS (S370L) Processor Board
Open Questions:
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
