The Lamp light is lit "red" - no picture. Help!
  • 5,138 Answers
Please Post your Brand name of TV and Model number it will be on back of TV then I will be able to give you correct information for Repair.
Posted on Oct 05, 2009
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
