Question about Buffalo Technology AirStation WLA2-G54L 802.11g/b (WLA2G54L) Wireless Access Point
Buffalo AP wla2 g54
I tried to upgrade my firmware and now i cannot connect to the AP
  • Chester Gould
    Chester Gould Dec 27, 2007
    Hello 2bob_watch,
    The above hardware refers to an access point. And I think I totally fried it... I even found the schematics and tried restarting it directly from the flash rom chip on the board. I am under the impression that the firmware does not even attempt to load, I know it is not trying to get an IP via DHCP, and the default IP 192.168.11.100 does not respond to ping nor are any ports open at all.
    Have any ideas? It still works as a hub, but I could have used another bridge to expand my wireless network.
    -Chester
  • ukdpw Jan 09, 2008
    I got a buffalo wyr g54 am trying to obtain new firmware old firmware is: version1 release31
  • 55 Answers
When you say you tried to upgrade your firmware, are you talking about in your router or your Access Point?
Posted on Dec 24, 2007
  • wezley paton Dec 28, 2007
    i would consider a dlink access point. All my wireless appliances run of it and it run smoothly. Even both my internet cameras run and don't miss a beat. Remember when you update you firmware make sure your Access Point is wired as you run the risk of damaging it when you update the firmware wirelessly
IF BUFFALO CAN SELL THESE ROUTERS THEN THEY SHOULD PROVIDE DRIVER/FIRMWARE UPDATES IN ALL LANGUAGES?
Posted on Jan 09, 2008
I have an emachine and installed airlink 101 ,,keeps kicking me off line..what do i do? i am online for 5 minutes then it kicks me off IE. says i am still connected.. HELP!! thanks
The following wireless access points/routers have been tested for use with the SoundBridge and SoundBridge Radio. While Roku is unable to provide testing results for all available wireless access point and routers, the vast majority will work fine with your SoundBridge product. We encourage you to try using your SoundBridge with your existing wireless equipment, regardless of published result before replacing your current hardware.
The current SoundBridge models, M1001 (connections on the back) and SoundBridge Radio R1000, use different wireless hardware than the older M1000, M500 and M2000 models (connections under the endcaps). This newer hardware has proven considerably more reliable than the older wireless hardware and should work out-of-the-box with virtually any 802.11b-compatible wireless equipment you may have. Compatibility of the older hardware has been improved over time and we recommend that you upgrade your SoundBridge's software to the latest version as soon as possible, particularly if your SoundBridge was delivered with software older than version 2.3.44. Upgrading older software may require using a wired ethernet connection or even taking your SoundBridge to a neighbors house or your office to sucessfully perform the upgrade.
To check your software version and perform an upgrade, use your SoundBridge remote control to navigate to the menu Change Library or Configuration -> System Configuration -> Software Version and Updates and follow the on-screen instructions.
If you still experience Wi-Fi connection problems, check the following items:
  • Make sure your access point/router is configured to allow 802.11b devices to connect. This may be phrased as "Mixed mode" or "802.11b +802.11g".
  • If you have wireless security enabled, make sure it is a supported protocol, and make sure you are using the "Hex" key. See your SoundBridge manual for more information.
If, after checking these items, you still cannot get your SoundBridge to connect to your wireless network, we encourage you to contact support or visit our Roku Community Forums where other customers and Roku employees will attempt to help you.
Bold = recommended by Roku for use with the latest version of SoundBridge software.
Red = poor performance or incompatible with SoundBridge
* = customer tested - your results may differ.
Model M1001,
R1000
M1000,M500,
M2000
Notes Airlink101 AR410W Yes Yes Fast! Apple Airport Extreme (Snow) Yes Yes Buffalo WBR-G54 Yes Yes Very reliable Buffalo WBR2-G54 Yes Yes
D-Link DI-514 B1 Yes Yes
D-Link DI 624 Yes Yes D-Link DI 784 Yes Yes D-Link DIR-655 * Yes Yes Set to b/g or b only. Problems reported in b/g/n mode. Linksys WAG300N * Yes Yes Disable wireless AP isolation. Linksys WRT51AB Yes Yes
Linksys WRT54G Yes Yes
Linksys WRT54GC Yes Yes Linksys WRT54GS Yes Yes Works great Motorola WA840G Yes Yes Works great Motorola WR850G * Yes Yes Wireless mode should be set to Compatibility. Problems have been reported with using Performance wireless mode. Netgear DG834Gv3 * Yes Yes Firmware v4.01.06 may be required for internet connectivity and WPA. Netgear DG834G Yes Yes Netgear WGR614 v5 Yes Yes Netgear WGT624 (all hardware revisions) Yes Yes Netgear RangeMax WPN824 Yes Yes Works great. Siemens GigaSet SE361 * Yes Yes SMC SMC2804WBRP-G Yes Yes Needs firmware v 1.956 or greater SMC SMC2804WBR Yes Yes
USR 8054 Yes Yes Needs firmware v 1.64 or greater XRouter Aero WSR-5000 Yes Yes ZyXEL Prestige 335WT * Yes Yes AirLink AR315W Yes Yes Poor performance Airlink AR420W * AP/Router/Switch No
AVM 3070 * AP/Router/Switch No
D-Link DI-524 AP/Router/Switch No Some users report this router works fine for them. Linksys BEFW11S4 No No. Performance is unacceptable Linksys WRT54GL * No No Downgrading to original firmware fixes rebuffering issues. Linksys WRT54GP2 Yes Yes Very slow performance Linksys WRT55AG Yes Yes Works, but some customers have reported issues with accessing the Internet through this device Netgear FVM318 Yes Yes May work for some, does not properly route UPnP discovery packets between wired and wifi Netgear MR814V2 Yes Yes Poor performance Netgear WGR614 v4 Yes Yes May require B-only mode . SpeedTouch 716G * Yes Yes Can connect wirelessly and stream locally, but no internet access. USR 5462 Yes No
Note: If your wireless access point does not work well with the SoundBridge, please make sure that both the SoundBridge and the access point are using the latest firmware available.
Apr 20, 2013 | Computers & Internet
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
Forgot admn passwaord
Create a password reset CD on another computer, then boot from CD in the locked computer, and it will allow you to reset your password.
Click HERE
to get the software and read the instructions carefully.
May 18, 2010 | Buffalo Technology Buffalo AirStation...
My son's ipod cannot connect with our internet? Also, when friends bring their computer and try to get on internet at the same time as I do, it will not let them on unless I am off internet.
You may want to check and see what kind of connection limitations are in place.
The router should have a static IP address *(like 192.168.1.1) or something close to that written on it.
You can use your web browser to log into your router and look at the settings.
Go to the Buffulo website for specific guidance on your model router.
Dec 28, 2009 | Buffalo Technology Buffalo AirStation...
Client Manager will not pick up my buffalo wireless card.
You can find the driver in the Buffalo download archive for older products:
http://site2.buffalotech.com/support/downloads2.php
Choose from the menu.
You also find manuals and set-up guides there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 31, 2009 | Buffalo Technology Buffalo AirStation...
Can't install client manager from buffalo
what are you trying to install ? you may want to run the installalation using the "Run as..." command
Jun 11, 2009 | Buffalo Technology Buffalo AirStation...
Device password requested on 1 or 4 laptops, 1 laptop can wiifii and no wiifii on the others
u set up ur buffalo airstation on the 1st laptop tat is working fine,,and at tat time u secured ur wireless network.so tat no one can else can connect to it..specially ur neighbours..u have to use tat password on the new computer.and tat will do it
May 09, 2009 | Buffalo Technology Buffalo AirStation...
Buffalo airstation router
If the power went out...it could have serged the router...try holding in the reset button for 30 sec....if no luck there take the router back where you purchased it and tell them it is faulty and needs replaced.
Nov 09, 2007 | Buffalo Technology Buffalo AirStation...
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Sep 19, 2007 | Buffalo Technology Buffalo AirStation...
Buffalo Technology AirStation WLA2-G54L 802.11g/b (WLA2G54L) Wireless Access Point Logo
423 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
