Too much yellow in the picture...new bulb - Televison & Video
    Sergeant:
  • 244 Answers
Make sure your new bulb has the same K (Kelvin- color) rating as your old bulb. may be printed somewhere on bulb. may be too yellow. also, make sure the bulb is properly installed, and not mis-aligned. this can make a difference in color mix in display.
good luck!
Posted on Oct 05, 2009
    President:
  • 267 Answers
Hi, The only way you can fix that permanently is by taking the TV apart and doing some complicating soldering (the key thing in your description being that the menus come up green). For a temporary fix, try hitting or jostling your TV, because when it becomes normal it might stay normal until another large hit. Or try dampening vibrations by placing it on top of styrofoam or something. Better yet.... just go ahead and buy a new TV. thank you for using fixya,rate my answer
vijay
LG tv has no picture
Your lamp most likely failed. You can get a new bulb for it for less than $100. RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG RU-52SZ51D 52" Rear Projection...
Wd60c9 lights blinking green sometimes,then yellow and finally red and no picture for any significant length of time
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
Feb 23, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
Yellow screen
my picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
Jan 22, 2013 | Philips Sony KDF55WF655 KDF55WF655 Lamp...
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
Feb 10, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
My TV has recently started to gat a yellow hue on
YOUR COLOR BULB IS GOING OUT GOT TO GET A NEW ONE.
Mar 18, 2009 | Televison & Video
The lamp yellow light keeps flashing so nothing works
you need to make sure the door is all the way tight. there is a switch there and if it is not making contact you will get a yellow status light
Feb 22, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
