Question about Toshiba SD-1200 DVD Player
Toshiba dvd player - SD-1200
When I put in cd, my player shows "loading" but then says "disc error" it won't even read a "cleaner disc" Help
  • 1 more comment
  • Scotte Dec 24, 2007
    I inserted a DVD and got loading, loading, loading...disk error. During the process it sounded like a lot of scratching. Is the player shot?
  • maetj6 Nov 22, 2008
    DVD continues loading, but never completes the task. Then
    message, "disc error" appears. Repeats the same each time
    I attempt to load DVD. Please help. Thanks.
  • jlflogix Jan 05, 2009
    won't read dvd lens cleaner disc???
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Posted on Jan 04, 2009
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
No disc found
i would try lens cleaner cd and is this likea store rented dvd also not a copy burned one or thx nick
Feb 09, 2008 | Toshiba SDV593 DVD Player / VCR Combo
Vizio vbr133 player . player starts to load disk and then reads no disk. tryed with different disk still reads no disk. error code HON7E
I was getting the same error and I could not get regular dvd or blu ray discs to play either. I dug out my old cd player lens cleaner and put it in and it started playing. I let it clean the lens for a couple minutes and now it is playing my movies again.
Jan 01, 2013 | Vizio VBR133 3D Blu-ray Disc Player
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
Put disc in player spins it, and says ERROR and
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say error and no disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | RCA RS2650 Shelf System
My dvd player plays cds but wont play dvds says disc error or unknown disc
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
When I put a audio disc in my cd player. I get on
this is a error code for can't read disc or bad lens. what you need to do first is try a cd cleaner in it first and then if not you will need to have it repaired because the lens can't read data.
hope you get it going with the cleaner! good luck
Nov 03, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Toshiba SD-1200 DVD Player Logo
408 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
