Question about Mitsubishi WS-65413 65" Rear Projection Television
The red is bowing at the top and bottom of the picture?
  • 934 Answers
Convergence amps shorted....
Posted on Oct 05, 2009
SOURCE:
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Dec 23, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi WS-65413 65" Rear Projection Television Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
