Question about Bionaire Heating & Cooling
Why does my heater shut off the power in the living room where I have it, I'm getting tired of having to go reset the breaker.
  • 8,197 Answers
If the heater is shutting off the breaker for the room that you have it in you have what we call a week breaker. You need to replace the breaker for a new one. Also it can be drawing to much amps with all the other equipment that you have in that room. You might want to try another plug that is on a separate breaker for that room .
Good Luck
Posted on Oct 05, 2009
I need help. My water heater all of a sudden stopped heating after an extension cord had shorted in the next room over. So could the problem be the breaker or the reset button which is stuck?
Check the breaker first and confirm that power is being delivered to unit. Then if power is confirmed, try the reset and make sure that power is now getting to the heating coils. If necessary, you can always jump the reset switch if it stays stuck.
Aug 26, 2015 | Water Water Heaters
We plugged in a small electric heater in the room with our Vizio plasma tv. All lights everything went out. I hit the breaker and everything came back on except the TV. No power at all. NO money must...
Hey Juuuudd..lol...not beatles...
Plug your tv into another outlet some where in another room and see if it works.
Check your tv owners manual and see if it has a "reset" button.
Usually, if this happens it because of the electric heater.
They tend to pull alot of power and blow power to your fuse box.
IE...if you have a 15 amp breaker and run 20 amps per say through it
it blows....or shuts off the power.....this happens alot at work with people
running heaters, lights etc.
if your problem persists let me know...good luck.
PS....don't run that heater...
Jan 26, 2011 | Televison & Video
I need to know where the reset buttons are located on the 30gal model 71-305 Rheem hot water heater. Help I'm not getting hot water so I'm trying to start with what may be a simple solution.
Shut off all power to water heater at breaker panel,remove side cover where thermostat is located. Test that there is no voltage at connections, with meter, to be 100% sure you shut off correct breaker. Thermostat should have a red button in middle to depress to reset if it's tripped.
Oct 23, 2010 | Rheem Water Heaters
Breaker tripped, wouldn't reset. After about 20 minutes it reset.
YES YOU ARE IN DANGER. DO NOT turn this breaker on again. Please get a registered electrician. There is a risk of fire or even explosion. BE CAREFUL. Have you got a smoke alarm?
Feb 05, 2010 | RTO Circuit Breaker Box For Electrical...
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Wiring two heaters off the same 240amp power source
FIRST YOU MUST DASIEY CHAIN THE 12-2 FROM THE PANEL TO FIRST HEATER IN THE LINE AND THEN TO THE SECOND HEATER IN THE LINE, ENDS OF BOTH WIRES IN THE SAME END OF HEATER,BREAK ONE SIDE OF THE LINE THROUGH THE THERMOSTAT AND TO THE ELEMENT OF THE FIRST HEATER AND THE SAME FOR THE SECOND HEATER BUT IN THE FIRST HEATER YOU WIRE IN TH LINE THE 2-BLACK WIRES AND THE 2-WHITE WIRES WILL STAY CONNECTED WITH WIRE NUTS AND YOU WILL CONNECT THE THERMOSTAT WIRING UNDER THESE SAME WIRE NUTS AFTER YOU STRIP THE ENDS OF BOTH WIRES ENTERING AND EXITING THE FIRST HEATER TREAT EACH HEATER AS IF YOU WERE ONLY WIRING ONE HEATER ONLY DIFF 2-BLACK AND 2-WHITE WIRES STRIPED OUT AT FIRST HEATER IN LINE FROM PANEL TO ACCESS AND CONNECT FIRST HEATER ,BB HEAT 250 WATTS PER FT
Nov 11, 2008 | Electrical Supplies
Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Heating & Cooling Logo
19 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
