Question about Canon PIXMA MP830 All-In-One InkJet Printer
I cleaned the printer head, installed new cartridges, and run the maintenance several times, but it still won't print evenly and the red does nont print at all. What else can I do?
  • Michael Grey
    Michael Grey May 11, 2010
    Remove the print head and inks.Soak head in a solution of 10-20%ammonia in warm water.Let sit for 60 minutes. Dry off completely and re-install.Do a nozzle check and if magenta is now coming out you need to run a deep cleaning. Check again.If not I do have a new head.
I soaked my print head in rubbing alcohol for about 10 minutes. I dried it off well. It works fine at this time.
Larry-Fulton
Posted on Jan 12, 2011
    President:
  • 787 Answers
The print head may clogged or defective. Replace it.
Posted on Oct 05, 2009
Replace pixma printhead
Print heads on this model run about $80 on ebay. Your best bet is to first replace the magenta cartridge even though it may appear to still have ink in it. After that, go into the maintenance menu and run a full cleaning cycle several times. This may clear your clogged print head.
Apr 18, 2014 | Canon Pixma MG8120 InkJet Printer
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
New ink not printing
If the printer is recognising the cartridge it is probably installed correctly. When you choose Print, check that the magenta image is red and showing a level. If you have run the purge and head cleaning options I would say you have a dud cartridge
Feb 19, 2010 | Epson Stylus C86 InkJet Printer
My bjc printer won't print. The paper goes through. The head/cartridge moves like it is printing but nothing. Tried everything in the maintenance manual.
If you have fresh ink cartridges installed and you have run the head cleaning maintenance and still have problems then the problem is most likely the print head ink nozzles are blocked.
This occurs then the printer has not been used for some time. To keep the nozzels from blocking the printer should be used once a week or the clean head maintenance run weekly.
There is no option other than to buy a new print head, they are not cheap.
Sep 08, 2009 | Canon Office Equipment & Supplies
Cant print
Ink button on? Check status monitor? I think is ink out message. Head cleaning for several time, throw ink too much. If u don't use CISS, after instaled ink tank, just wait for 1 hour before use printer. Ink will flow to head itself.
Jun 12, 2009 | Epson Stylus C43UX InkJet Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Low ink level after ink refill prohitting print function
Click on your lexmark maintenance tools and click on install new cartridge. This should fix your problem.
Mar 29, 2008 | Computers & Internet
Canon PIXMA MP830 All-In-One InkJet Printer Logo
144 people viewed this question
old marine
old marine
