Question about Kenmore Elite 45986 Front Load Washer
The washer stops and flashes f35 and some times
  • 8,197 Answers
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Posted on Oct 05, 2009
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F35 flashing mean? I own a Kenmmore elite front loading washer and besides it being broke down most of time it is pretty but doesn't work most of the time. This week it is flashing F35, I bought...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%&#@
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
169 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
